line continuation character
Results 1 to 6 of 6
    Jun 2016
    Default line continuation character
    I need to arraywrite a long string (173 characters) but cannot find any reference to the continuation character and how to use it!
    Anybody can help me?
    thank you
    Alberto
    Edited: OK I finally have found the page! Page 61 of the manual and the correct spelling is: Line Extention and the caracter is the underscore (_)
    But still have some problem on how to use it.
    Arraywrite string,["abcdefghiklmn"_
    "opqrstuvwxz"_
    "1234567890",13,10]
    is this the corrected way to use it?
    Tank you again
    Alberto
    Default Re: line continuation character
    Yes, Alberto That is correct.
    EN82fn
    Jun 2016
    Thank you Dave for the quick response.
    Unfortunatly I am not able to write the string in three lines neither in two lines, I get an error 346 Expected "]" but the "]" is there!
    The actual string contains an underscore in the text "private_key" could it be the reason?
    Fortunatly the whole string stay in one single line and the code compile, but I wonder why I cannot use the line extention.
    Alberto
    Alberto, I have used this line extention quite a bit in the past like this:
    lookup2 (CHARACTER - 32),[$0000,$0030,$0202,$12CE,$12ED,$2424,$0B59,$0200,$0 039,$000F,$3F00,$12C0,$2000,_
    $00C0,$4000,$2400,$243F,$0406,$00DB,$00CF,$00E6,$0 0ED,$00FD,$0007,$00FF,$00E7,_
    $1200,$2200,$0C00,$00C8,$2100,$1421,$2D3F,$00F7,$1 28F,$0039,$120F,$00F9,$00F1,_
    $00BD,$00F6,$1209,$001E,$0C70,$0038,$1536,$0936,$0 03F,$00F3,$083F,$08F3,$018D,_
    $1201,$003E,$2430,$2A36,$2D00,$1500,$2409,$0039,$0 900,$000F,$2800,$0008,$0100,_
    $00DF,$0878,$00D8,$208E,$0079,$0071,$018F,$00F4,$1 000,$000E,$0C30,$1200,$10D4,_
    $1050,$00DC,$0471,$08E3,$0050,$018D,$0078,$001C,$2 010,$2814,$2D00,$028E,$2409,_
    $2149,$1200,$0C89,$00C0,$3FFF],OUTWORD
    I wonder if the Arraywrite string command has the issue?
    EN82fn
    Quebec, Canada
    You need to add some comas:
    Arraywrite string,["abcdefghiklmn", _
                       "opqrstuvwxz", _
                       "1234567890",13,10]
    Jun 2016
    Thank you Michel, thank you Dave, yes it was the missing coma!
    Now I can continue with my coding knowing that I can break a long line of code.
    cheers
    Alberto
  1. character return from PIC to VB
    By macinug in forum Serial
    Last Post: - 29th April 2009, 11:58
  2. Can It Be this SIMPLE? (the Off-Topic continuation)
    By Mike_Lynch in forum Off Topic
    Last Post: - 28th August 2006, 15:08
  3. LCD Character Generator
    By crematory in forum mel PIC BASIC Pro
    Last Post: - 20th September 2005, 16:07
  4. Line continuation
    By stratus in forum mel PIC BASIC
    Last Post: - 14th June 2005, 08:17
  5. 2 Line Chars on a 2 Line LCD
    Last Post: - 16th November 2003, 00:44
