I've tried using the parasite power option and can not seem to get it to work at all. Is there something I'm missing from my code? It works fine using three wire but not two.
Code:read_temp: owout portb.7,1,[$CC, $44] ' Send start temperature conversion owout portb.7,1,[$CC, $BE] ' Send read scratchpad command for x = 0 to 8 ' Process all 9 bytes owin portb.7,0,[i] ' Read the scratch pad dq[x] = i ' Place read byte into the array next x ' Do again until all 9 bytes are processed temp.Byte0 = dq[0] : temp.byte1 = dq[1] ' Store bytes 0 and 1 in the temp word variable if temp.8 = 1 then ' If bit8 of temperature is set then its negative sign = "-" ' Indicate temperature is NEGATIVE temp.lowbyte = temp.lowbyte ^ 255 ' Reverse the bits of the lowbyte of TEMP sign = " " ' Indicate temperature is POSITIVE endif half = temp.0 temp = ((temp.lowbyte) >> 1) * 10 ' Shift the lowbyte of the result right 1 place temp = temp + (half * 5) ' Strip off bit 0 (0.5 degree) and add it to DEC
					 DS18S20 & Parasite Power
