Installation Advice Please
Results 1 to 8 of 8
    Mar 2011
    Los Angeles, California
    Question Installation Advice Please
    Hi All!
    I just upgraded my computer and need to reinstall all my stuff. I have 4 disks one is white labeled PBP3 Picbasic Pro Compiler, another is Blue, labeled Microcode Studio Plus, another silver/blue, labeled MPLAB IDE V 7.00a, and the forth is Black and labeled Picbasic Pro Compiler Upgrade. Do I need to install all four and in what order? Thanks in advance.
    Best, Ed
    Default Re: Installation Advice Please
    I'd start with PBP, white then blue. It should tell you if the version is required.
    Then run B&W update. Same thing, it should tell you if it's required or not.
    Then Microcode Studio, so you can set in options where you installed PBP.
    Are you sure some are not older PBP 2?
    You can also check on the cd, readme files which version they are. I use a black marker to label my CDs.
    Then I'd check the web sites to know which version of MCSP and MPLAB is compatible with which version of PBP.
    Doesn't it say on the discs which version they contain? Just install the lates one and be done with it, no need go thru each and every version (if you don't want or need to HAVE) each and every version installed of course.
    Then install MicroCodeStudio and let it find the PBP installation folder.
    Mar 2011
    Maybe I have created some confusion? Here is what I have and I downloaded the MPLAB IDE 8.92 so I know the 7.00a is old. I think I need to install the black disk?
    Is it a PBP 3 upgrade?
    Browse the CD and check out the Readme file.
    Or just click the setup exe on it and see what it says on the opening screen.
    Mar 2011
    The Black CD says PBP2.60c
  1. Found label after column 1 : Unsucessful Installation ?
    By truffaldino in forum mel PIC BASIC Pro
    Last Post: - 26th October 2014, 19:25
  2. Installation. Include file not found?
    By thronborg in forum General
    Last Post: - 18th March 2011, 19:46
  3. MPLAB ICD2 progammer installation problem
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 8th February 2011, 03:33
  4. ic prog installation
    By sakthi in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 14:01
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
