LCD Displays
Results 1 to 2 of 2
Thread: LCD Displays
    Roland's Avatar
    Roland Guest
    Default LCD Displays
    I am using the PIC 16f88 with a-d and proven concept and function using LED displays. It is now time to convert to LCD( Less Power Battery operated device). I need 3 digits with 3 seperate commons. The LCD's I find have only 1 common point which prevents me from stobing all 3 digits.I developed using common anode but am willing to switch to common cathode.Small is good .56 max.
    Roland
    Post
    I've never seen 3 digit displays with more than one common, neither have i've seen 1 digit displays smaller than one inch.
    You need atleast 25 outputs to drive a 3 digit LCD. One simple(and cheap) way of getting theese is by using 74HC595 chips. They are easy to use, cheap and consume very little power(if run slowly).
  1. lcd stops after about 5 minutes and gets stuck
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 15th September 2009, 12:03
  3. Play with LCD on PICDEM
  5. LCD will not start
