Microchip Assembly Commands
Results 1 to 7 of 7
    Nice job. I like the brief description.
    Your document will go well with this as an index.
    http://ww1.microchip.com/downloads/e...Doc/31029a.pdf
    Default microchip assembly commands
    The following shows you which device families include which instructions.
    PIC Microcontroller Instruction Set Comparison Matrix
    http://www.piclist.com/techref/membe...RA4/PICISM.HTM
    Mpasm Assembler User Guide
    http://ww1.microchip.com/downloads/e...Doc/33014K.pdf
    And this gives you a way to perform 8 and 16 bit compares, as well as an example of 16 bit subtraction, using assembly (in case you need it for ASM interrupts).
    http://www.piclist.com/tecHREF/microchip/compcon.htm
    Last edited by ScaleRobotics; - 29th October 2010 at 16:10. Reason: added Mpasm User Guide Link
    Dec 2008
    New York US
    Wink
    Big thanks to picnaut, mackrackit, and scalerobotics for sharing usefull info.
  1. Assembly Guru : Question
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 20th May 2007, 04:51
  2. Parse Strings from (Assembly) Serial Interrupt
    By orlandoG in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 17:17
  3. from assembly to basic
    By shantanu in forum Off Topic
    Last Post: - 1st February 2007, 15:50
  4. Assembly Language + PBP
    Last Post: - 10th January 2006, 14:54
  5. How do you do this in Assembly
    By ice in forum mel PIC BASIC Pro
    Last Post: - 10th May 2005, 07:47
