Defining Long Variable
Results 1 to 5 of 5
    Jun 2013
    Default Defining Long Variable
    I am using PBP3,try to use PIC18F27J53 to do collect some data and I need the long variable,I use the code var long and it return the error long datatype no supported,use -n option for LONG datatype support,does PIC18 do not support LONG datatype of I miss out something?thank you
    Dec 2010
    Default Re: Defining Long Variable
    selected "use compiler long words" in options?
    Hello,
    type in to the Optional Command Line box
    -n
    and compile the program, this may can help.
    Jun 2013
    I try tonight,thank you
    Jun 2013
    no error reported,thank you,next will try on some basic data gather using the long word and confirm the result ,thank you very much
  1. LCDOUT with a LONG Variable
    By MarkEngineer in forum mel PIC BASIC Pro
    Last Post: - 16th January 2015, 16:31
  2. Defining COM-2
    By Ramius in forum Serial
    Last Post: - 11th May 2011, 12:35
  3. How long a variable has the same value?
    By DanPBP in forum General
    Last Post: - 22nd February 2008, 23:54
  4. signed long (32-bit) variable
    By Stephan in forum mel PIC BASIC Pro
    Last Post: - 11th September 2007, 03:40
  5. Defining MCU with MPASM
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 24th May 2007, 13:16
