Counting better ?
Results 1 to 17 of 17
    Aug 2005
    antipolo city, philippines
    Default like a thread...
    franko,
    yes. once the initialization process of TIMER1 interrupt is complete and activating the start of counter, the timer will run in background as you work on your main code. it will only then be entering the interrupt service routine once it reached the overflow anytime and anywhere while you are working on your main routine.
    regards,
    yettie
    We should learn "KISS" - Keep It Simple Stupid...
    Franko's Avatar
    Franko Guest
    I read about the timer(s) running in the background in Melanie's Olympic timer.
    I've looked through the data sheets. How does one learn more about how to use the timer functions ? Proper way to write the code ? Reccomended books ?
    Franko
    Aug 2005
    franko,
    good day! i had not read any reading materials except for the microchip datasheet. you can have a guide there of what bits you will manipulate. for TIMER1, such bits are T1CON, PIE1.1, PIR1.1, and for interrupts INTCON. you would want to experiment it and discover what you can do. I bet it will be more satisfying. Melanie's olympic timer example is your best guide. I'm sure you can do it.
    regards,
    yettie
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Remain counting while sending out a pulse
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 10th January 2007, 16:51
  3. hardware counting while software runs
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 04:26
  4. continious counting process (capture)
    By asynch in forum General
    Last Post: - 17th February 2006, 08:42
  5. Counting Button Pushes
    Last Post: - 27th November 2005, 23:10
