Counting better ?
Results 1 to 17 of 17
    Franko's Avatar
    Franko Guest
    Default Counting better ?
    I'm trying to get this to count pulses from an opto detector which goes High when the beam is broken.
    Problems are,it stops the Hmtr at three pulses instead of four and if the beam isn't broken in quick succession,hmtr continues to run no matter how many times beam is broken.
    My complete thanks to Melanie for the first (most so far) part of code!
    CMCON=7
    'Declare Variables,Constants and Aliases for Ports
    In1 VAR PORTA.1 'pulse input from selector 24vac/dc via optocoupler
    In2 VAR PORTA.2 'pulse input from selector 24vac/dc via optocoupler
    In3 VAR PORTA.3 'pulse input from selector 24vac/dc via optocoupler
    Button1 VAR PORTA.4 'pulse input from selector 24vac/dc via optocoupler
    Hmtr VAR PORTB.0 ' motor on/off
    DATAPLS VAR PORTA.0 'sense output from passthru opto
    Alert VAR PORTB.1 'Beeper
    CounterA VAR BYTE 'counter
    i VAR WORD 'General purpose variable
    'Set initial state of ports
    Hmtr=0 ' motor off
    TRISA = %11111111 'Make all Porta pins Inputs
    TRISB = %00000000 'Make all Portb Outputs
    Pause 500 'Settling time
    'Start of program
    runloop:
    While In1=1 'Wait here for input pulse
    CounterA=0 'Rest time counter
    Wend
    Timerloop:
    While Button1=1 'Wait for dispense button to be pressed
    CounterA=CounterA+1 'Increment counter by 100ms
    IF CounterA=200 Then Startloop 'If 20 sec elapses,goto start and await new activation
    Pause 100 'Wait 100ms for smooth operation
    Wend
    runit:
    High Hmtr
    Pause 100
    While DATAPLS=0 'wait for High from passthru opto
    Wend
    GoSub cnt
    GoTo runloop
    cnt:
    PulsIn DATAPLS, 1, i
    IF i > 4 Then
    Low Hmtr
    Else
    GoTo runit
    EndIF
    Any suggestions ?
    Thank you
    Aug 2005
    antipolo city, philippines
    Default use pull ups
    franko,
    what is your configuration for you PORTA inputs? did you used a pull down resistor to ground? You have an alternative to use internal weak pull-up features (OPTION_REG=7). PIC have sensitive inputs if you used pull downs. I had some problems that I also count the noise spikes if i used external pull downs, and most likely in activating motors. the motors are inductors that could spread some unwanted signals seen by the microcontroller. proper hardware design could prevent this kind of problems.
    also, use
      ...(code here in betweens)
    for ease. thanks
    regards,
    yettie
    We should learn "KISS" - Keep It Simple Stupid...
    Franko's Avatar
    Franko Guest
    Hi Yettie,
    The config for porta pins are as inputs (if I did the code right).inputs A.1 and A.4 are pulled high via a 470 ohm. A.0 is pulled low via a 470.
    I've never tried setting the internal pull up/dn but I will.The motor is power by a seperate 24vdc supply but with a common ground.The motor is switched by a relay which is controlled by the PIC via a NPN transistor and the coil of the relay has a diode across the coil and is correct direction.
    I presume the problem is with the way I've done the code as I'm still learning (and loving it). I'll use the Quote function in the future as you said.
    Thanks for your ideas.
    Franko's Avatar
    Franko Guest
    Is it that no one sees anything wrong with this ? There must be something wrong with how I've done it.
    I'm not asking for anyone to write it for me,rather just some advice on the correct way to make the motor low after four (or whatever) pulses.
      runit:
    High Hmtr
    Pause 100
    Wend
    GoSub cnt
    GoTo runloop
    cnt:
    IF i > 4 Then
    Low Hmtr
    Else
    GoTo runit
    EndIF
    Isn't using a 470R resistor a little low for a pull-up? Using a value this low will only increase the current the IO has to produce in order to change the pins state.
    Aug 2005
    Default typical pull-up value
    franko,
    some points:
    - cokekid seems to be right. try to increase the pull-up to 10K.
    seems to be your PULSIN DATAPLS,1,i is the culprit. if theres anyway you can monitor your WORD "i", verify it. If you have a serial port, plug it. otherwise you'll be convinced of what you will find out. then recode. it's my style of debugging.
    yettie
    Franko's Avatar
    Franko Guest
    Yeah, I agree with you CocaColaKid and yettie, I usually use 1K or 10K (depending).But, I breadboarded this kinda quickly and grabbed what I had the most of.
    I'll switch them to 10K and see if that makes any difference.
    Yetti, I'm not sure what you mean by...
    " seems to be your PULSIN DATAPLS,1,i is the culprit. if theres anyway you can monitor your WORD "i", verify it."
    But I'll keep trying different methods.
    Thanks for the advice,
    Franko
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Remain counting while sending out a pulse
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 10th January 2007, 16:51
  3. hardware counting while software runs
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2006, 04:26
  4. continious counting process (capture)
    By asynch in forum General
    Last Post: - 17th February 2006, 08:42
  5. Counting Button Pushes
    Last Post: - 27th November 2005, 23:10
