Modem Auto Answer-Hanging for 1 min...
Results 1 to 22 of 22
    Have you tried issuing a single command string?
    hserout ["ATX3 AT&K0 ATS0=3",13,10]
    Just wondering if you are trying to stuff the next command into the modem whilst it's still trying to acknowledge the first one you gave it. So increase the pause also.
    harrisondp's Avatar
    harrisondp Guest
    Your PIC's input buffer may be overflowing, which may cause the pic to 'freeze'.
    Add the following line if you don't already have one in your program:
    DEFINE HSER_CLROERR 1
    Harrison
    Thanks for the replies.
    Melanie:
    Yes I tried to send the commands all together and it seems to work OK. But I do not know why, since there is no check from the program if the module has accepted the previous string...
    I was thinking that the problem might be from the PIC itself side.
    harrisonsp:
    The command suggested is always included in my programs. Also the response from the module is set to be in numeric mode rather than in ASCII, so the flow is reduced to a zero for "OK".
    Still mystery covers the case....
    No, I don't think it's the PIC. I would place money on it being the modem.
    With a lot of modems with 'Hayes Style' command set, when you issue a command, the modem will reply (even if it's OK or just a plain CRLF).
    It is possible that during this reply the PIC has issued the next command (intercommand Pause too short)... and in so doing the modem has lost part of the next command string receiving a corrupted sequence which in turn has caused it to timeout.
    You could verify this by increasing the Pauses to something really long (eg PAUSE 5000 rather than 500) and see if it still hangs. If it doesn't, then that's the reason... your modem probably has poor firmware that can't simultaneously cope with a new command string whilst the reply to the previous one is still being processed.
    Don't quote me, but I think there's a command to suppress these responses from the modem... you could always issue that first. That might also stop the problem.
    Hmm, how much would you bed on it?? **smiles**!
    The problem is still there. I just moved the sub's from top of program to the bottom of it and this part works OK now! Any explains? I usually put all sub's on top.
    It is weird...
    P.S. Of course half of the sub's do not work!!!
    Is that an invitation?
    Short of going through your program line by line I can't comment, but what version of PBP are you using? I do recall early versions of PBP did have some issues, and I do recall some strange things in 2.42... but ceratinly not now.
    Just curious if when you send all commands at once are you certain that all commands are received and processed? The PIC might sending the info too fast and the modem is only responding to one of the commands when it replies "OK". This I think would be along the same lines as Melanie thoughts.
  1. No Modem response
    By jimboho in forum mel PIC BASIC Pro
    Last Post: - 11th November 2004, 06:58
