Darrel,
Can I make the program with the version demo, if it is can he/she tell this way me as?.
Thank you again
Originally Posted by Darrel Taylor
Darrel,
Thank you again
Well, if it doesn't need to be exact, you might do something like this.<BR><BR>Code:Minutes VAR Byte Hours VAR Byte Days VAR Byte Wait40Days: For Days = 1 to 40 For Hours = 1 to 24 For Minutes = 1 to 60 PAUSE 60000 ; 60 Seconds Next Minutes Next Hours Next Days
Hello Darrel,
Thank you for the code, I want that when push RB.0 he lights the led on RB.1 after the fixed time lapses I have carried out the tests and I have not been able to make it work, you can help me and to say eats up I please make it.
I am using a PIC16F628.
Thank you
<table><tr><td nowrap><img src="http://toons.artie.com/alphabet/ralph/arg-n-50-trans.gif"><img src="http://toons.artie.com/alphabet/ralph/arg-o-5O-tRr-a-pl0ase-ns.gif"></td></tr></table><br><br>
Try going here... http://www.melabs.com/resources/index.htm#Manuals<br><br>
Hello Darrel, I have bought the PBP and I am happy, if I need its aid I can write to him?.
Leonardo
Hello Leonardo,
Leaonardo, Dave gave you some wonderful working code... You can do it on your 675 if you want....Code:Minutes VAR Word Hours VAR Word Days VAR Word loop: HIGH LED GOTO LOOP OPTION_REG = $7f Wait40Days: For Days = 1 to 40 For Hours = 1 to 24 For Minutes = 1 to 60 PAUSE 60000 ; 60 Seconds Next Minutes Next Hours Next Days
Now about your code...
loop:
HIGH LED
GOTO LOOP
None of your pins are assigned to outputs... granded HIGH changes it to OUTPUT, but turn off your AD's and compariters for "Habit" sake.
you have this loop, and it is going to turn on your LED...but never turn it off...
Your interput is not configured properly... check out the manual on how to use interupts...
your subroutine of 40 days is does not have a return, nor does it have a interupt turnoff.
Dwayne
Ability to Fly:
Pilots that are Flying:
Hola Leonardo,
Ahora que usted tiene PicBasic Pro. La manera más fácil de hacer el programa de 40 días es utilizar el primer ejemplo que di al principio de este thread.
Primero, usted necesita Download el programa de
http://www.picbasic.co.uk/forum/showthread.php?t=190
Entonces, intente esto...Code:<font color="#008000"><b>CLEAR </b></font><b>Bcount </b><font color="#008000"><b>VAR BYTE INCLUDE </b></font><font color="#FF0000">"Elapsed.pbp" </font><font color="#0000FF"><b><i>; Include the Elapsed Timer Routines </i></b></font><font color="#008000"><b>GOSUB </b></font><b>ResetTime </b><font color="#0000FF"><b><i>; Reset Time to 0d-00:00:00.00 </i></b></font><b>Start</b>: <b>Bcount </b>= <b>0 MainLoop</b>: <font color="#008000"><b>BUTTON </b></font><b>PORTB</b>.<b>1</b>,<b>0</b>,<b>200</b>,<b>255</b>,<b>Bcount</b>,<b>1</b>,<b>Start40 </b><font color="#0000FF"><b><i>; Wait for button press </i></b></font><font color="#008000"><b>PAUSE </b></font><b>1 </b><font color="#008000"><b>GOTO </b></font><b>MainLoop Start40</b>: <font color="#008000"><b>GOSUB </b></font><b>StartTimer </b><font color="#0000FF"><b><i>; Start the Elapsed Timer </i></b></font><b>Loop40</b>: <font color="#008000"><b>IF </b></font><b>DaysChanged</b>= <b>1 </b><font color="#008000"><b>THEN </b></font><b>DaysChanged</b>= <b>0 </b><font color="#008000"><b>IF </b></font><b>Days </b>= <b>40 </b><font color="#008000"><b>THEN </b></font><font color="#0000FF"><b><i>; Has it been 40 days </i></b></font><font color="#008000"><b>GOSUB </b></font><b>StopTimer </b><font color="#008000"><b>GOSUB </b></font><b>ResetTime </b><font color="#0000FF"><b><i>; Reset Elapsed Timer </i></b></font><font color="#008000"><b>HIGH </b></font><b>PORTB</b>.<b>0 </b><font color="#0000FF"><b><i>; Turn ON output </i></b></font><font color="#008000"><b>PAUSE </b></font><b>10000 </b><font color="#0000FF"><b><i>; Hold output high for 10 seconds </i></b></font><font color="#008000"><b>LOW </b></font><b>PORTB</b>.<b>0 </b><font color="#0000FF"><b><i>; Turn OFF output </i></b></font><font color="#008000"><b>GOTO </b></font><b>Start </b><font color="#0000FF"><b><i>; go back to beginning. </i></b></font><font color="#008000"><b>ENDIF ENDIF </b></font><font color="#0000FF"><b><i>; .. You can do other things here while waiting for 40 days (if needed) .. </i></b></font><font color="#008000"><b>GOTO </b></font><b>Loop40</b>
Darrel,
You helps me with the code so that it works.
Thank you
'* Name : TIMER 40 DAYS.BAS *
'* Notice : Copyright (c) 2005 [select VIEW...EDITOR OPTIONS] *
'* : All Rights Reserved *
'* Date : 13/08/05 *
'* Version : 1.0 *
'* Notes : *
' Turn LED on. Interrupt on PORTB.0 (INTE) turns LED off.
PUSH VAR PORTB.0
LED var PORTB.1
Minutes VAR Word
Hours VAR Word
Days VAR Word
loop:
HIGH LED
GOTO LOOP
OPTION_REG = $7f
Wait40Days:
For Days = 1 to 40
For Hours = 1 to 24
Next Minutes
Next Hours
Next Days
