moramlik,
use SERIN2 command. refer to the PBP manual http://www.microengineeringlabs.com/...ces/pbpmanual/. it will be more convincing if you will learn it. But of course you should know the basic hardwire connections, (Tx pin of Serial Cable to "used to be" Rx pin of your PIC with a limiting resistor).
regards,
