Interrupt problem.
Results 1 to 3 of 3
    Hi Peter,
    Looks like you're reloading timer1 before it can over-flow (not sure without knowing the osc speed), but try something like this.
    PRESET  VAR WORD
    ELAPSED VAR BYTE
    PRESET = 12000
        T1CON=%00110000  ' Set timer1 prescaler as 1:8
        PIR1.0=0	       ' Clear timer1 overflow flag
        PIE1=%00000001      ' Enable interrupt on timer1 overflow
        TMR1H=PRESET.highbyte  ' Load timer1 high byte
        TMR1L=PRESET.Lowbyte  ' Load timer1 low byte
        T1CON.0=1               ' Turm on timer1
        INTCON=%11000000   ' Global & peripheral interrupts enabled
        ON INTERRUPT goto TICKER
    MAINLOOP:
        TOGGLE PORTB.5
        ELAPSED = ELAPSED + 1
        GOTO MAINLOOP
        DISABLE
    TICKER:
        TOGGLE PORTB.0          ' Toggle PORTB.0
        TMR1H = PRESET.highbyte ' Load timer1 high byte
        TMR1L = PRESET.Lowbyte  ' Load timer1 low byte
        PIR1.0=0                ' Clear TMR1 overflow flag
        RESUME
        ENABLE
    HTH....;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Thumbs up
    Yeah, Thanks Bruce, that done it.
    Isn't it amazing, once again my problem was so simple that I couldn't see it for trying. Makes me feel like a bloody idiot, (as is usual with my little errors) when that happens. The theory was right, just the placement wrong. Anyway, thanks a lot Bruce for your assistance.
    Peter Moritz.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 02:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
