Interrupt problem.
Results 1 to 3 of 3
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Interrupt problem.
    G'day all you smart people. Would someone be so kind as to help me out with an interrupt (and Timer1) problem. Sometimes we old blokes get caught up with all this new technology.
    I have been playing with PICs for a few years, but this is the first time I have used interrupts or Timer1.
    This is the reelvent code:
    Blah, Blah, usual setup stuff here.
    T1CON = %00111001 '1:8 prescaler
    PRESET = 12000
    'This should load the counter
    'ELAPSED = 0
    MAINLOOP:
    T1CON.0 = 0 'stop the clock
    TMR1H = PRESET.highbyte 'RELOAD THE COUNTER
    TMR1L = PRESET.Lowbyte ' "
    T1CON.0=1 'START THE CLOCK
    PIR1.0=0
    ON INTERRUPT GOTO TICKER
    PIE1.0=1
    INTCON.6=1
    INTCON.7=1
    LCDOUT $fe,1, elapsed 'this is only for seeing what happens - 'NOT required in final
    TOGGLE PORTB.5 'nor this bit
    ELAPSED = ELAPSED + 1
    GOTO MAINLOOP
    DISABLE
    TICKER:
    'PAUSE 1000
    'toggle portb.5 'same as above note
    T1CON.0=1
    PIR1.0=0
    RESUME
    ENABLE
    OK, when I look at the LCD and Portb.5 in the mainloop, the port line toggles OK, the LCD is too fast to read, but something is on the display, just can't see it.....So far so good.
    When I disable the LCD and port in mainloop and enable it in the interrupt loop, the port line does not toggle, neither does the LCD show anything.
    Quite obviously the thing is not jumping to the interrupt handler, or an interrupt is not being generated.
    I have to ask someone for some help, as I ain't got any hair left to pull out. Been working on this now for 3 nights.........
    Thank you, in advance,
    Peter Moritz.
    Hi Peter,
    Looks like you're reloading timer1 before it can over-flow (not sure without knowing the osc speed), but try something like this.
    PRESET  VAR WORD
    ELAPSED VAR BYTE
    PRESET = 12000
        T1CON=%00110000  ' Set timer1 prescaler as 1:8
        PIR1.0=0	       ' Clear timer1 overflow flag
        PIE1=%00000001      ' Enable interrupt on timer1 overflow
        TMR1H=PRESET.highbyte  ' Load timer1 high byte
        TMR1L=PRESET.Lowbyte  ' Load timer1 low byte
        T1CON.0=1               ' Turm on timer1
        INTCON=%11000000   ' Global & peripheral interrupts enabled
        ON INTERRUPT goto TICKER
    MAINLOOP:
        TOGGLE PORTB.5
        GOTO MAINLOOP
        DISABLE
    TICKER:
        TOGGLE PORTB.0          ' Toggle PORTB.0
        TMR1H = PRESET.highbyte ' Load timer1 high byte
        TMR1L = PRESET.Lowbyte  ' Load timer1 low byte
        PIR1.0=0                ' Clear TMR1 overflow flag
        RESUME
        ENABLE
    HTH....;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2005
    Thumbs up
    Yeah, Thanks Bruce, that done it.
    Isn't it amazing, once again my problem was so simple that I couldn't see it for trying. Makes me feel like a bloody idiot, (as is usual with my little errors) when that happens. The theory was right, just the placement wrong. Anyway, thanks a lot Bruce for your assistance.
    Peter Moritz.
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 20:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 02:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 21:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 02:17
