Unable to execute mpasmwin
Results 1 to 4 of 4
    oldmainframer's Avatar
    oldmainframer Guest
    Default Unable to execute mpasmwin
    Please forgive what I'm sure is a noob question.
    I just bought PB Pro, USB programmer, and installed it all from the CDs using the defaults. Read the MPLAB IDE v7.40 help, created project, made a .bas file, set the device, compiled and then get the following. I gather it compiled OK, as it built the .asm file, but it can't execute mpasmwin, the assembler?
    I verified the path that's set in the IDE points to mpasmwin.exe. There is a similar thread in this forum that I followed, but things seem to check out correctly. Other ideas?
    Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -v -p12C672 "12c671.bas"
    PICBASIC PRO(TM) Compiler 2.47, (c) 1998, 2006 microEngineering Labs, Inc.
    All Rights Reserved.
    Pass 1:
    Pass 2:
    Code Gen:
    Macro Pass:
    mpasmwin /q C:\IBM_PICS_09032006\PCB_Boards_08262001\BTL_MB_4\ Halloween2005\12c671.ASM
    ERROR: Unable to execute mpasmwin.Skipping link step. Not all sources built successfully.
    BUILD FAILED: Thu Nov 02 16:18:04 2006
    This may help... or not... as the case may be....
    http://www.picbasic.co.uk/forum/showthread.php?t=536
    Just go to the directory where mpasmwin.exe is located and rename it as mpasm.exe and it should work now. I just had the same problem an hour ago when I loaded picbasic pro and code studio, which I may say rocks.
    I tried all of the other brand X compilers and non would do anything like picbasic pro does.
    Mike
    Tcrook's Avatar
    Tcrook Guest
    Default Re: Unable to execute mpasmwin
    Been using PBP 2.50 on W XP for a long time. Just getting started again with PBP3 on W 10 and I am unable to fix this darn 'unable to execute mpasmwin' problem. Think I've tried all the suggestions here including the PATH variable in Windows but no joy. Anyone successful with this configuration? Still using MPLAB 8.15.
    I tried MPASMX but after severe hair loss I gave up on that.
    Any thoughts?
  1. Behaviour of MPASMWIN in MCSP
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2010, 14:31
  2. Replies: 3
    Last Post: - 20th December 2009, 13:57
  3. MPASMWIN and VISTA
    By Charles Linquis in forum General
    Last Post: - 1st September 2009, 07:02
  4. Replies: 1
    Last Post: - 27th August 2009, 03:42
  5. MicroCode Studio Plus won't use mpasmwin
    By sjohansson in forum USB
    Last Post: - 4th January 2007, 23:10
