Yettie, I'm pretty sure I loaded a good HEX file each time,but I'll try again.My input is 16v to the Epic.I was referring to the output from the onboard adjustable regulator to the onboard 5v reg.
Luciano, I did not check that. I'll give it a try !
Thank you very much !
