Recomended Programer ???
Results 1 to 19 of 19
    Franko's Avatar
    Franko Guest
    Darrel,
    I hope I'm missing something and not just being a dimwit,but when I click on the link "Download XP_stop_polling.reg (1K)"at meLabs all that comes up is the text. I don't see any place to choose run or anything. Bad link or ???
    Somethings probably messed up the association with the .reg files.
    Right click on the link and choose Save Target As..., and save the file to your hard disk.
    Open regedit, and go to the File | Import dialog and locate the file that you saved.
    Darrel
    Franko's Avatar
    Franko Guest
    OK, The reason the file wasn't working is because I was using Firefox as my browser and the meLab site evidently doesn't support it for that kind of file.
    I changed back to IE and the file worked perfect.Now I keep getting the unable to start driver PICLPTNT error.
    This happened before and I got it working but I can't remeber how I fixed it before.
    Thanks for the help and your patience.
    Franko's Avatar
    Franko Guest
    I removed the PICLPTNT driver and reinstalled it as administrator and that took care of that, I checked the registry and the stop polling file is there.
    The last,most persistant problem is "code programing error 0000".
    No matter what PIC is in the epic or none at all. I'm using the same EPIC,same cable,same power supply that worked perfect on the old laptop.
    Does anyone have any other ideas ? I appreciate all the help.
    Franko
    Do a forum search on "error 0000". Your problem is probably covered in the list.
    Franko's Avatar
    Franko Guest
    Default Sincere thanks
    Hi all,
    Well, I increased the voltage in the Epic via VR1 from 13.4v to 13.7v and it stopped giving the error code 0000 and indicated that it was programming and verifing with no problem. But it actually was not programming the PIC at all.
    So, after trying everyones ideas and mine, I've switched back to my old 98SE laptop and will order a serial Epic soon."I don't know what else I can do"
    And I did do searches here and at the meLabs site also, but still ???
    Thank you all for your time and kind and helpful responses !
    Franko
    Aug 2005
    antipolo city, philippines
    Default view the code...
    franko,
    i'm using the EPIC parallel programmer at 15V input. Verify that you opened the correct HEX file by opening the View-Code (MENU). Of course 3FF means nothing.
    regards,
    yettie
    We should learn "KISS" - Keep It Simple Stupid...
  1. epic programmer not found ---HELP!
    By dmacq in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 20:38
  2. Programer Error
    By WireMan in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 10:03
  3. Which PBP Compiler are you using?
    By Melanie in forum General
    Last Post: - 24th January 2006, 18:42
  4. Replies: 5
    Last Post: - 16th September 2005, 17:38
