Recomended Programer ???
Results 1 to 19 of 19
    Franko's Avatar
    Franko Guest
    Thank you all.
    Darrel, I saw that file but not exactly sure how/where to add it. I know how to get into the regedit.
    Can you please advise me ?
    I also tried the meprog beta version and it gave it's own strange problems.
    Piece of cake. Just click on the file, then choose RUN when prompted, or save it somewhere on your hard disk, then double click on it after downloading.
    It will prompt if you want to add this information to the registry. Click Yes. It will give a confirmation that it was completed. Then re-boot the computer for it to take effect.
    HTH,
       Darrel
    Franko's Avatar
    Franko Guest
    Darrel,
    I hope I'm missing something and not just being a dimwit,but when I click on the link "Download XP_stop_polling.reg (1K)"at meLabs all that comes up is the text. I don't see any place to choose run or anything. Bad link or ???
    Somethings probably messed up the association with the .reg files.
    Right click on the link and choose Save Target As..., and save the file to your hard disk.
    Open regedit, and go to the File | Import dialog and locate the file that you saved.
    Darrel
    Franko's Avatar
    Franko Guest
    OK, The reason the file wasn't working is because I was using Firefox as my browser and the meLab site evidently doesn't support it for that kind of file.
    I changed back to IE and the file worked perfect.Now I keep getting the unable to start driver PICLPTNT error.
    This happened before and I got it working but I can't remeber how I fixed it before.
    Thanks for the help and your patience.
    Franko's Avatar
    Franko Guest
    I removed the PICLPTNT driver and reinstalled it as administrator and that took care of that, I checked the registry and the stop polling file is there.
    The last,most persistant problem is "code programing error 0000".
    No matter what PIC is in the epic or none at all. I'm using the same EPIC,same cable,same power supply that worked perfect on the old laptop.
    Does anyone have any other ideas ? I appreciate all the help.
    Franko
    Do a forum search on "error 0000". Your problem is probably covered in the list.
  1. epic programmer not found ---HELP!
    By dmacq in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 20:38
  2. Programer Error
    By WireMan in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 10:03
  3. Which PBP Compiler are you using?
    By Melanie in forum General
    Last Post: - 24th January 2006, 18:42
  4. Replies: 5
    Last Post: - 16th September 2005, 17:38
