Recomended Programer ???
Results 1 to 19 of 19
    Jul 2005
    Hi
    If you stop polling problem you can use it, also, it may be a problem with the driver, reinstall the driver again, and stop the polling, I had these problems when I started using XP.
    Hi Franko,
    I use the EPIC with Media Center version of XP and they work great together. All you need to do is modify the registry a bit.
    Go to this page at meLabs
    http://www.melabs.com/support/patches.htm
    Down at the bottom, in the Stop Windows XP from polling printer port section, is a file you can download that automatically makes the registry changes for you.
    HTH,
       Darrel
    Franko's Avatar
    Franko Guest
    Thank you all.
    Darrel, I saw that file but not exactly sure how/where to add it. I know how to get into the regedit.
    Can you please advise me ?
    I also tried the meprog beta version and it gave it's own strange problems.
    Piece of cake. Just click on the file, then choose RUN when prompted, or save it somewhere on your hard disk, then double click on it after downloading.
    It will prompt if you want to add this information to the registry. Click Yes. It will give a confirmation that it was completed. Then re-boot the computer for it to take effect.
    HTH,
       Darrel
    Franko's Avatar
    Franko Guest
    Darrel,
    I hope I'm missing something and not just being a dimwit,but when I click on the link "Download XP_stop_polling.reg (1K)"at meLabs all that comes up is the text. I don't see any place to choose run or anything. Bad link or ???
    Somethings probably messed up the association with the .reg files.
    Right click on the link and choose Save Target As..., and save the file to your hard disk.
    Open regedit, and go to the File | Import dialog and locate the file that you saved.
    Darrel
    Franko's Avatar
    Franko Guest
    OK, The reason the file wasn't working is because I was using Firefox as my browser and the meLab site evidently doesn't support it for that kind of file.
    I changed back to IE and the file worked perfect.Now I keep getting the unable to start driver PICLPTNT error.
    This happened before and I got it working but I can't remeber how I fixed it before.
    Thanks for the help and your patience.
  1. epic programmer not found ---HELP!
    By dmacq in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 19:38
  2. Programer Error
    By WireMan in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 09:03
  3. Which PBP Compiler are you using?
    By Melanie in forum General
    Last Post: - 24th January 2006, 17:42
  4. Replies: 5
    Last Post: - 16th September 2005, 16:38
