LCD Problem witch PIC16F676
Results 1 to 3 of 3
    Aug 2005
    Question LCD Problem with PIC16F676
    Hi all!
    I'm using a PIC16F676 with a 16x2 LCD (CDL4162) but I can't get LCDOut to work!
    This LCD today work without problem with a PIC16F874A...
    these are my DEFINES:
    Define LCD_DREG PORTC ' Port for LCD Data
    Define LCD_DBIT 4 ' so I have
    ' D7 on portc.5
    ' D6 on portc.4
    ' D5 on portc.3
    ' D4 on portc.2
    Define LCD_RSREG PORTA ' Port for RegisterSelect (RS) bit
    Define LCD_RSBIT 1 ' Port Pin for RS bit on porta.1
    Define LCD_EREG PORTA ' Port for Enable (E) bit
    Define LCD_EBIT 0 ' Port Pin for E bit on porta.0
    Define LCB_BITS 4 ' Using 4-bit bus
    Define LCD_LINES 2 ' Using 2 line Display
    Define LCD_COMMANDUS 2000 ' Command Delay (uS)
    Define LCD_DATAUS 40 ' Data Delay (uS)
    Are my connections true?
    at the benigging of the program i added this:
    ANSEL = 0
    CMCON = 7
    and I try to view something with:
    lcdout $fe,1, "Hello Friends!"
    Please help me!!
    thanks to all!
    In four-bit mode for PICBasics LCD commands, your LCD connections can be...
    Portx.0, Portx.1, Portx.2 and Portx.3
    or
    Portx.4, Portx.5, Portx.6 and Portx.7
    Make your choice, then make your corrections.
    Aug 2005
    Thank you very much Melanie.
    Today I will try your suggestions.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
