WORD bug
Results 1 to 7 of 7
Thread: WORD bug
    Sorry, but I still do not understand why you think this is a bug?
    With the PIC operating at 8MHz, you have an execution speed of 2 million single cycle instructions per second. That's fast..!
    If you increment decideInterval on each pass through your loop, of course it will = 600 at some point. And very quickly.
    Here's another example;
    init:
          decideInterval  var  WORD
          TIMEINTERVAL	  con  600
          decideInterval = 0
          decideInterval = decideInterval + 1
          IF decideInterval = TIMEINTERVAL then
              decideInterval = 0
              GOTO Match
          GOTO  MAIN
    Match: ' End up here in approximately 11.4mS
          GOTO Match
    From Main, through the loop once, then back to Main at 8MHz only takes around 19uS. Now take 19uS * 600 for ~11.4mS.
    It takes only ~11.4mS before you increment decideInterval from 0 to 600, and then the IF/THEN statement evaluates as TRUE, and program flow jumps to Match.
    Note: I verified this (PBP v2.46). It does not jump to match at 11. Only once
    decideInterval = 600.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2005
    antipolo city, philippines
    Default i consider it as BUG still...
    bruce,
    to make things clear. i've written it in a program to have a 31.25ms timer at a prescale of 1:8,yielding a 250ms to overflow TIMER1. i verified it in a oscilloscope that it is accurate.
    define  debug_reg    	porta		'nevermind my serial LCD display debugger
    define  debug_bit   	0
    define  debug_baud   	2400
    define  debug_mode   	1
    define  inthand     	checkNow
    define OSC 8
    CMCON=7
    time	var	word
    timeL	var	time.byte0
    timeH	var	time.byte1
    decideTimeInterval	var	word
    setup:
      debug   12,"Starting",10,13,"   Program",4
      pause   2000
      intcon  = %11000000   ;setting up gie and peie bits
      time    = 3036          	;calibrated to have 31.25ms scale
      tmr1L   = timeL         	;65536 - time (preload value)
      tmr1H   = timeH
      flag    	= 0
      PIR1.0  = 0
      PIE1.0  = 1
      T1CON   = %110001    ;setting up to 1:8 prescale
                              	;31.25ms x 8 = 250ms/count
      if flag = 4 then        	;(250ms x 4 = 1s) second ticker
         flag = 0
         decideTimeInterval = decideTimeInterval + 1
         gosub  updateTime
      if decideTimeInterval = TIMEINTERVAL then		;this one is the notorious routine. it's just a reset condition.
         decideTimeInterval = 0				;It resets unexpectedly.  In contrast to this,
      endif							;changing the decideTimeInterval to BYTE and of course
    							;TIMEINTERVAL <= 255 will function properly
    updateTime:
      DEBUG "Time:",#decideTimeInterVal
    ;interrupt handler
    @checkNow
      pie1.0  = 0
      flag    = flag + 1
      time    = 3036
      toggle = portb.3		;my monitor to oscilloscope, it accurately toggles at 250ms cycle
      TMR1L   = timeL
      TMR1H   = timeH
      PIR1.0  = 0
      PIE1.0  = 1
      resume
    i hope now that everything clear for you now. the decideTimeInterval counter now increments every second avoiding fast incrementing, like you said.
    any ideas?
    thanks and I appreciate very much
    regards,
    yettie
    Hi Yettie,
    I couldn't get your code to compile without errors. Try this;
    @ DEVICE MCLR_OFF,LVP_OFF,HS_OSC,WDT_OFF
    DEFINE  OSC 8
    define  debug_bit   	0
    define  debug_mode   	1
    CMCON=7
    TRISB.3=0
    'Variables for saving state in interrupt handler
    wsave	           VAR	BYTE $70 system		' Saves W
    ssave	           VAR	BYTE bank0 system	' Saves STATUS
    psave	           VAR	BYTE bank0 system	' Saves PCLATH
    fsave	           VAR	BYTE bank0 system	' Saves FSR
    time	           var	word
    flag               var  byte
    setup:
      pause   2000
      tmr1H   = time.highbyte
      tmr1L   = time.lowbyte   	;65536 - time (preload value)
      flag    = 0
      PIR1.0  = 0
      PIE1.0  = 1
      T1CON   = %00110001    ;setting up to 1:8 prescale
         flag = 0
         gosub  updateTime
    updateTime:
    ;interrupt handler
    asm
    checkNow
        ; Save FSR, PCLATH, STATUS and W registers
        movwf	 wsave          ; Save W
        swapf	STATUS, W   ; Swap STATUS to W (swap avoids changing STATUS)
        clrf	STATUS	     ; Clear STATUS
        movwf	ssave	     ; Save swapped STATUS
        movf	PCLATH, W   ; Move PCLATH to W
        movwf psave	     ; Save PCLATH
    	; isr routine
        bsf STATUS,RP0  ; bank 1
        bcf PIE1,0
        bcf STATUS,RP0  ; bank 0
        incf _flag,f    ; increment flag
        movlw 0x8
        xorwf PORTB,f   ; toggle portb.3
        movf _time,W
        movwf TMR1L
        movf _time+1,W
        movwf TMR1H
        bcf PIR1,0
        bsf PIE1,0
        ; Restore FSR, PCLATH, STATUS and W registers
        movf	fsave, W      ; retrieve FSR value
        movwf	FSR	     ; Restore it to FSR
        movf	psave, W	     ; Retrieve PCLATH value
        movwf	PCLATH	     ; Restore it to PCLATH
        swapf	ssave, W	     ; Retrieve the swapped STATUS value (swap to avoid changing STATUS)
        movwf	STATUS	     ; Restore it to STATUS
        swapf	wsave, F	     ; Swap the stored W value
        swapf	wsave, W     ; Restore it to W (swap to avoid changing STATUS)
        retfie		     ; Return from the interrupt
    endasm
    Look in the manual, and at some of the MeLabs examples for assembler interrupts to find out why it works.
    -Bruce
    tech at rentron.com
    Aug 2005
    Default It's working
    Hi Bruce
    the code is actually working to my circuit. it's just that there might have some differences in our compilers. i'm compiling it in PBP with IDE of microcode. just to study the (bug?), i'm changing the "time" variable to WORD or BYTE modifier. using the WORD seems to be not working properly other than the byte. i already prototyped this program and testing it further. I will share you further info of what more I can find out. thanks!
    Yettie
    yettie
    We should learn "KISS" - Keep It Simple Stupid...
  1. Read/Write Problem
    Last Post: - 10th February 2010, 01:51
  2. Minimizing code space
    Last Post: - 30th May 2009, 07:25
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  4. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 8th July 2008, 23:19
  5. calculation problem
    Last Post: - 31st March 2006, 15:23
