How to Design 5V power supply?
Results 1 to 4 of 4
    Nov 2016
    Default How to Design 5V power supply?
    Hello,
    I want to learn how to design power supply source of 5V some amps from 220V AC To DC
    Apr 2012
    Ptolemaida
    Default Re: How to Design 5V power supply?
    Hello RITESH,
    you can check this video out!!
    If you are a begginer with electronics then i would suggest you to buy a new power supply from your electronics store, in order to avoid accidents with 220v AC line.
    One man's magic is ANOTHER man's engineering.
    Supernatural is a null word
    Mar 2011
    Los Angeles, California
    Hi RITESH!
    You might also consider buying a multi-voltage output bench supply so you are not limited to only 5v dc. Not sure what your application is and if you are experimenting with different projects you may need 12v dc, or 9v dc, or???
    Ed
    I use old PC power supplies: 12, 5, 3.3 and any combination you want.
  1. power supply help ?
    By iugmoh in forum Schematics
    Last Post: - 27th February 2009, 21:01
  2. Alternative power supply
    Last Post: - 20th November 2007, 14:38
  3. Backup Power Supply
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 19th August 2007, 20:37
  4. Transformerless Power supply
    By nikhil in forum mel PIC BASIC Pro
    Last Post: - 17th January 2007, 08:07
  5. Dual Power Supply Design
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 17th October 2006, 05:11
