Hserin
Results 1 to 8 of 8
Thread: Hserin
    Mar 2016
    Default Hserin
    Hi.
    I am having a problem trying to receive certain data over one byte using the WAIT ( ) modifier in PBP.
    Here is my problem shown below. These are the characters that I receive from a certain chip when I send a reset to it.
    Sent data:
    HSerout ["AT+RST",13,10]
    Received data (HSERIN):
    2nd boot version : 1.5
    SPI Speed : 40MHz
    SPI Mode : DIO
    SPI Flash Size & Map: 8Mbit(512KB+512KB)
    Ai-Thinker Technology Co. Ltd.
    ready
    The problem is that I only want to display "ready" on my 2X16 display.
    hserin [WAIT("ready"),RX0,RX1,RX2,RX3,RX4]
    hserin [WAIT($79),RX0,RX1,RX2,RX3,RX4]
    hserin [WAIT("r","e","a","d","y"),RX0,RX1,RX2,RX3,RX4]
    hserin [WAIT($72,$65,$61,$64,$79),RX0,RX1,RX2,RX3,RX4]
    I tried all these above variations and none work for me. If I use the "." at the end of "Ltd."
    in the above example it would work because I would get everything after the "." which is "ready"
    Problem is that there are "." before the "Ltd." like at the "1.5" so I get everything after that.
    How does one go about doing this. Do I use "WAITSTR". If yes, I have tried and dont quite understand how to use it.
    Hope this makes sense.
    Help is greatly appreciated.
    Default Re: Hserin
    hserin [WAIT("Ltd."),skip 2 ,RX0,RX1,RX2,RX3,RX4]
    the skip 2 is for the expected CR,LF {CHR13,CHR10}
    Then rx0--4 should be "ready"
    Mar 2016
    Default Re: Hserin
    Thanks Richard!
    This looks good! I'll give it a try.
    Don't know why I did not think of this? Over thinking maybe?
    Thanks again.
    Mar 2016
    Default Re: Hserin
    Hi Richard.
    I don't quite get somehing with HSERIN. Your first example worked great I got "ready" on my 2X16 display. But after that I cant get
    any other replys to work They just sit there waiting.
    EG.
    I am sending out "AT+CWMODE=1" and my reply is:
    AT+CWMODE=1
    OK
    I would like to start the next command after receiving "OK" so I know the first setting was excepted before I go on to the next.
    But for some reason the PIC never "sees" "OK".
    Test program:
    LCDOut $FE,1,"Setting STA mode"
    LCDOut $FE,$C0,"Please wait....."
    pause 2000
    HSerout ["AT+CWMODE=1",13,10]
    hserin [WAIT("OK") ,RX0,RX1,RX2,RX3,RX4,RX5]
    pause 2000
    LCDOut $FE,1,"Set connection "
    pause 2000
    HSerout ["AT+CIPMUX=1",13,10]
    I never get to "Set connection ". Just hangs on WAIT("OK").
    I have tried to go back to start of program in case the reply was missed with this
    hserin 100,start, [WAIT("OK") ,RX0,RX1,RX2,RX3,RX4,RX5]
    but it will go around and around for ever.
    I hate to bother you again but I have spent most of the weekend and I just cant get it.
    Any help would be appreciated .
    Default Re: Hserin
    the device responds
    OK(chr13,chr10) or OK(chr10)
    so
    RX0=13,RX1=10 and then hserin will wait forever trying to fill rx2-5 because no more serial data is forthcoming
    either use a timeout or
    hserin [WAIT("OK") ]
    Aug 2003
    Default Re: Hserin
    With hserin you can receive one byte at a time into a buffer until you see the return character,
    and then look at the rest of the command you received.
    Mar 2016
    Default Re: Hserin
    Okay. Will try tomorrow.
    Thanks again for your help.
    Mar 2016
    Default Re: Hserin
    Thanks for the info! Tomorrow I will try again.
  1. HSerin
    By GatorGuy in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 05:04
  2. Hserin
    Last Post: - 26th February 2010, 12:36
  3. hserin
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 18:15
  4. Hserin
    Last Post: - 20th March 2006, 23:09
  5. Hserin
    By MICOCALI in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 09:09
