Pic to GSM Phone connection (HSerin problems)
Results 1 to 40 of 289
    Talking
    Ralph,
    in addition to that, this awesome F84 is one of the first flash device from Microchip and can still be found everywhere and at local electronic parts provider... like 12C508
    for the remainder, you know why i did it
    Apr 2005
    Talking
    And it is also weird.....
    It's the ONLY PIC available in our electronics store!!!
    That's why I have no choice...
    BTW:
    Is there a FREE PicBasic compiler and some links for tutorials??
    aruran's Avatar
    aruran Guest
    Talking Nokia... and SMS
    Sorry to ask you all again. I didn't quite get it Mr.kasamiko since the phone's voltages are little lesser
    than 5V. So why the hell we should use max232 to connect to the pic. I didn't quite understand it. I thought
    if I connect it to the PIC directly through the interface given http://www.atrox.at/datacable/dlr3/index.html
    But I am not farely clear what pins I should omitt. I thought that the phone's MBUS and GND are the only pins connected. As posted by stu746 I didn't realy understand the circuit modification. Enybody please help me......? If you could send me the circuit for any nokia connecting to a PIC only would be of immense help.
    I will be greatful to you all
    regards
    aruran
    On the above code:
    HSerin 5000,loop,[wait("UNREAD"),skip 3,STR Caller\13,skip 4,STR GSMTime\17,skip 6, STR GSMBUFFER\16\13]
    it would be good to change UNREAD to READ since the phone can answer also "REC READ" or other "READ" messages.
    Apr 2005
    Question
    Quote Originally Posted by Ioannis
    On the above code:
    What is the purposed of this code modification? and in what particular above code?
    Feb 2004
    Germany
    kasamiko,
    see comments
    As I was interrested in "NEW" Messages only (the ones I had not already taken action on) "UNREAD" was correct.
    regards
    Ralph
    aruran's Avatar
    aruran Guest
    Question Help
    It seems though everybody are ignoring my problem. Please take a minute to help me.
    thanks
    aruran
    Apr 2005
    Quote Originally Posted by aruran
    regards
    aruran
    MAX232 was used on that circuit since it was designed to be used for PC. If you're planning to use that as stand-alone on Nokia's like 6210, you can omit MAX232..
    I have a circuit to be connected for 6210 but I dont have a code for PIC to have it receive an SMS then activate a relay.
    What I need is a PIC16F84 with 8 mhz xtal and can drive a 4 relay when it received an SMS command..
    I know sa AT commands for Nokia but don't know how would I start it..
    Any sample codes will be appreciated.
    TIA
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 21:33
  4. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  5. Pic to GSM Phone connection
    By samertop in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 14:40
