Again:
Please stop sending PMs asking: would Phone Model X work?
I definitely don't know all brands and models available on the market.
And I don't know the pinouts of all those different connectors.
Further down on this thread there is a working code example that can easily be modified for a different PIC type or Phone type.
If the documentation of your specific phone says it has an embedded modem you should be able to get it working.
First try it in Hyperterm, it doesnt make much sense to hook the GSM up to the PIC as long as you havent figured out what the Comms parameters should look like.
If you try the code example with a phone other than mentioned in that posting chances are it will work, but YOU will certainly have to do some homework.
(I'm not going to do it for you)
I'm sure if you google for your particular phone model you will find more descriptions of connectors and interfaces than you'll ever need.
