I can't bro "tamad ako magsulat" hehehe!!! but the mere fact someone "hacked the cable" instead of buying the expensive one i'm pretty much sure you will find tons of applications!!! RECYCLING is one thing!!!
EVERYBODY in this Forum AVR-guys are getting so much popular making add-on applications for MEGASQUIRT!!! they even developed this LCDASH dashboard and it's freaken jam-packed!!! i believe if you want PICMICRO to hold its position lets start projects for megasquirt too!!! as a start i created idle servo controller for an old 1992 lancer watch my video!!!
Can someone help me direct to a website where I can purchase oneline cheap GSM Module? Any help will be greatly appreciated. Thanks in advance.
Here you go bro look for BENQ gsm modules GPRS capable also using standard AT modem commands!!!
http://www.e-gizmo.com/
i have maked : http://ktl.kauko.lt/~av2/projektai/gsm/1.png
pic16f84a and phone siemens c55
test program:
define OSC 10
Rx var PORTA.0
Tx var PORTA.1
Led VAR PORTA.3
speed = 84
start:
high led
pause 2000
serout2 Tx, speed,["ATD+37060000000",13,10] <--- in this step, phone turn off, whay???
pause 10000
low led
for this scheme (http://ktl.kauko.lt/~av2/projektai/gsm/1.png) are hex (http://ktl.kauko.lt/~av2/projektai/gsm/softas/1010.rar) and it work fine
The DLR3P found on this site http://www.atrox.at/datacable/dlr3/index.html is already "HACKED" of the original..and it is working perfectly..thanks to the author..
