Pic to GSM Phone connection (HSerin problems)
Results 1 to 40 of 289
    So i hope you have include the Max232 (icl232) too?
    As Steve asked, did you used the 232 chip? What do you mean by "only the right portion"?
    Ziki's Avatar
    Ziki Guest
    hi ...ioannis ..how do i disable the echo?ATEO mean? ..is it necesssary to off it ???
    thxxx....
    Yes. Please do disable the response from the mobile since everything that you type is echoed back so you can see it on the terminal window. But on the microcontrler it is not needed. In fact, it messes with the UART as it is getting characters.
    ATE0 (<-- this is zero, NOT letter O) is AT command to disable echo. Not that after a reset, this cames back to normal, so you have to send it again. Say on top of the program.
    Ziki's Avatar
    Ziki Guest
    ok..thx...
    can you have a look at this thread ....
    http://www.picbasic.co.uk/forum/showthread.php?t=4425
    i use serin since hserin canot work ....
    but don't know why ...it can only store the 1st data into the variable -buffer(1)
    since the speed is reduced to T300 ...it should be able to catch it right ?
    i try using 8Mhz ...also no luck ....
    thxx
    Sorry, cannot help any more. It seems to be something with your mobile. All the schematics is OK. About PDU I have no idea and to be honest, I don't want to get!!!
    I always used phones with text ability and in control applications Wavecom and Telit modules.
    I think that you have timing problem since the Hserin/Hserout is the best command on the PBP repertore. Of course a string handling needs to be improoved, but that's another thread story.
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  4. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 07:57
  5. Pic to GSM Phone connection
    By samertop in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 13:40
