Help me with this please
Results 1 to 3 of 3
    mnkjoi's Avatar
    mnkjoi Guest
    Default Help me with this please
      • Hey ,
        Could someone helps me please with this :
        Write a program that will check the input of 2-input quadruple NAND , if the NAND gate works properly then the LED connected to RD6 should be ON , otherwise the LED should be ON . Assume PORTC connected to the inputs of quadruple 2-input NAND gates , two LEDs connected to most two bits of PORTD .
        Using pic assembly language .
        • If the four nand gates outputs matching the truth table , then we say the quad two input nand gate is working properly and the GOOD LED is On .
          Please help me with this code .
    Default Re: Help me with this please
    Don't you want to know how much most charge by the hour first?
    looks pretty easy
    asm
    MOVE?CT 0, TRISD, 6
    MOVE?CT 1, PORTD, 6
