String functions
Results 1 to 3 of 3
    Default Re: String functions
    yes, string functions can be implemented with pbp code blocks but just like in your "serout code space " thread
    what looks like a simple code block often turns out to be larger,slower,clunkier and having much less functionality than a properly integrated
    piece of code . unless its done in asm of course but thats no guarantee . asm code that takes full advantage of chip resources over the range
    of chips that pbp supports is not that simple to implement , with 8/16 bit fsr's , linear memory etc it gets complicated.
    i'm sure programers could integrate some handy equivlents of some useful C functions ,but a lot can be emulated anyway
    len() eg for j = 0 to len(mystr): do stuff : next
    equiv j=0: while mystr[j] : do stuff : j=j+1:wend
    strcat() eg newstr = oldstr+mystr (c strcat(newstr,oldstr); strcat(newstr,mystr) )
    equiv arraywrite newstr,[str oldstr,str mystr]
    atoi() eg int j = atoi(mystr)
    equiv arrayread mystr,[dec j]
    strok() missing in action
    Aug 2003
    That's pretty much what I think,
    hence I'd like to hear what native string handling is supposed to achieve.
    The most fun to write that I can think of right now is sprintf with format modifiers
    that would naturally extend the length of the original string,
    but then if you had the string with all the nice verbose numbers in it, what use would it be?
    Especially when the likes of lcdout and serout do the same thing.
  1. String types and functions AND Functions with arguments
    By PickyBiker in forum PBP Wish List
    Last Post: - 1st January 2015, 09:00
  2. Replies: 3
    Last Post: - 3rd December 2011, 22:48
  3. How to send a string with another string inside it?
    Last Post: - 13th May 2011, 17:11
  4. Where are the String Functions?
    By circuitpro in forum General
    Last Post: - 14th June 2009, 01:44
  5. A real String type & functions to match
    By Phil Moore in forum PBP Wish List
    Last Post: - 25th December 2008, 16:45
