Time window
Results 1 to 8 of 8
Thread: Time window
    Franko's Avatar
    Franko Guest
    Default Time window
    I've been programming Pics for a while now and mostly done somewhat basic
    routines(although very useful to me). Anyway,I have been trying to write code to do the following...
    Upon a pulse to a pin,activate a timer within the Pic (16F84A) that would allow another input to a different pin to activate the main code.
    So, After the first input pulse you would have say 20 sec to press the button that would activate the code. After the 20 sec has timed out, pressing the button would do nothing until another input pulse starts the timer again.
    I've tried variations of count,pulsein,for/next,searching here and can't get it.
    Can someone please just point me in the right direction ?
    Franko
    Nov 2004
    I've done this sort of 'timeout' routine by sending the program into a tiny loop which monitors only the desired pins, after the main stimulus has been received.
    Each time the miniloop executes, a counter is incremented.
    If I receive an appropriate response (button, etc), I clear the counter and jump to the appropriate section of my code.
    If the counter increments and reaches $BIGNUM, I exit the loop and go back to the main program.
    John
    Aug 2005
    antipolo city, philippines
    Default consider PIC16f628
    franko,
    consider yourself using a PIC16F628 since it has TIMER features. It will be a lot more easier since PIC16F84 have limited capabiliities. Another thing, it's a more cost efficient device for compared to other one.
    in case you consider it, use can use particularly the TIMER1 feature of the device for it can count up to 1/100th (or better) of a second accuracy.
    regards,
    yettie
    	PulseInput var PortB.0		' Pin is HIGH with Pulse taking it LOW
    	ButtonInput var PortB.1		' Pin is HIGH with Button Press taking it Low
    	LED var PortB.2			' LED will Light when all Conditions Met
    	CounterA var Byte		' Just a variable to Count 20 Seconds
    	TRISB=%00000011			' Setup Port I/O
    	LOW LED				' LED is OFF
    	Pause 500			' Settling Timeout of 500mS
    StartLoop:
    	While PulseInput=1:Wend		' Wait for Pulse Here
    	CounterA=0			' Reset 20 seconds Counter
    TimerLoop:
    	while ButtonInput=1		' Loop waits for Button-Press
    		CounterA=CounterA+1	' Increment Counter every 100mS
    		If CounterA=200 then StartLoop
    					' Redo from Start if 20 seconds elapsed
    		Pause 100		' Kill 100mS
    		wend
    MainCodeSuccess:
    	High LED			' Light LED
    	Pause 5000			' for 5 Seconds
    	Low LED
    	Goto StartLoop			' And start over again
    This is basically an example of what John/JEC first mentioned above. Enjoy.
    Franko's Avatar
    Franko Guest
    Thank you all for your fast replies !
    I have several 628s and will use them.
    Melanie, That is extremely kind of you to do the code example,I appreciate it very much.
    I have spent 2 days on this and now I can continue on.
    Thanks again,
    Franko
    Test it, Test it, Test it!
    I wrote it off the top of my head, in five minutes at quarter to two in the morning at the end of a long day, so make sure it works, it makes sense and more importantly that you understand it before 'moving on'.
    Franko's Avatar
    Franko Guest
    I will test it today and reply back. I read it over several times last night so as to understand all the steps and what they do.
    As I test this one section alone, I will understand it even more.
    Franko's Avatar
    Franko Guest
    It works !
    Melanie, I only had to make one change to get it to work...
    CounterA=0
    I moved Wend to "after" CounterA=0...
    While PulseInput=1
    CounterA=0
    Wend
    Before I did that, LED would High anytime ButtonInput went Low.Now it only goes High during the "Time Window".
    Works great and now I'll tweak it to suit my application and continue.
    Thanks!!!
  1. I don't understand this code!
    By Russ Kincaid in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 03:55
  2. Measuring time
    By AugustoPedrone in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 00:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 20:55
  4. Alarm Time
    By Santana in forum Code Examples
    Last Post: - 8th December 2006, 14:58
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
