Need Help To Understand This Program
Results 1 to 3 of 3
    Hi Danish,
    Just wondering if you're covered with Cream Cheese. Mmmmmmm.
    The BUTTON command will never time out because B0 is getting reset to 0 on every loop. It will never reach a full count. Try putting the B0 = 0 outside the loop, something like this.
    B0=0
    loop:
        BUTTON 1,1,254,0,B0,1,ButttonPressed
        TOGGLE 0
        PAUSE 500
    GOTO LOOP
    ButttonPressed:
    ' ... code here ...
    goto loop
    ADDED: I should probably mention that the PAUSE 500 with a BUTTON delay of 254 will mean you'll have to hold the button down for 128 seconds before it will jump to the Button pressed routine. So a smaller delay or pause will be needed.<br>
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
