HELLO CAN ANYONE HELP ME UNDERSTAND THIS PROGRAM I MEAN I UNDERSTAND BUT ONE THING I DONT GET AND WHY DOESN'T IT DO IT I PUT A TOGGLE COMMAND IN THIS PROGRAM WITH THE BUTTON COMMAND AND THE PROGRAM WORKS PERFECTLY AND BUT WHEN EVERYBODY KNOWS WHEN THE BUTTON IS PRESSED IT GOES TO THE LABEL IT IS ASSIGNED TO IF THE ACTION IS TRUE AND WHEN IT SCANS THE BUTTON COMMAND AND IT IS NOT PRESSED IT GOES TO THE TOGGLE COMMAND AND THEN IT TURNS OFF THE LED BUT WHEN IT RESTARTS THE LOOP AND SCANS THE BUTTON COMMAND AGAIN AND IT IS NOT PRESSED THEN GOES TO THE TOGGLE COMMAND THEN THE TOGGLE SHOULD TURN OFF THE LED BECAUSE THATS WHAT THE TOGGLE COMMAND DOES WHEN THE LED IS HIGH IT TURNS IT LOW AND WHEN IT IS LOW IT TURNS IT HIGH HERE IS THE PROGRAM TO GIVE YOU AND IDEA ABOUT WHAT I AM TALKING ABOUT :
loop: B0=0
BUTTON 1,1,254,0,B0,1,loop
TOGGLE 0
PAUSE 500
GOTO LOOP
CAN ANYONE REPLY BACK TO ME I WOULD REALLY APPRECIATE A REPLY
