16F690 read/write
Results 1 to 14 of 14
    Default Re: 16F690 read/write
    this is what I tried , it works fine
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_ON
    cfg&= _IESO_ON
    cfg&= _FCMEN_ON
      __CONFIG cfg
    DEFINE OSC 8 ; tells PBP we use a 8 MHZ clock
    OSCCON = %01110000
    ANSEL = 0  ;set all digital
    TRISA = %110100    ; Set RA5,RA4 and RA2 input, rest output
    TRISB = %0000     ; PORT B all output
    TRISC = %00000000  ; PORT C all output
    CM1CON0 = 0 ' Disable comparator 1
    CM2CON0 = 0 ' Disable comparator 2
    led1 var portc.4
    buton1 var porta.4
    led1flag var bit
    low led1
    let led1flag = 0
    init:
    read 10,led1flag
    pause 2
    if led1flag = 1 then
    high led1
    low led1
    if buton1 = 0 then
    let led1flag = 1
    goto writetoeeprom
    writetoeeprom:
    write 10, led1flag
    pause 2
    debounce:
    if buton1 = 0 then goto debounce
    goto init
    Hello Richard,
    basically this is my code without changes, but after try It isn't work. Then I try to replace the chip (the previous is an brand new out of the box) to another brand new and ...
    ... man all works, the trevious chip was faulty, two days of labour and time wasting. Thank You for all support .
  1. SD Card Write/Read
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 28th April 2014, 09:26
  2. PLEASE HELP...read write issues
    By nomad77 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 15:39
  3. Can't read an sms Using TC35i & 16F690
    Last Post: - 4th October 2009, 23:41
  4. I2C Read and Write
    By DerekMacom in forum mel PIC BASIC
    Last Post: - 21st April 2008, 16:44
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 12:46
