Hello Richard,
here is a complete code with config:
The WRITE and READ instructions works on 16F628, 16F688 as is in the code, but on 16F690 still not.Code:'* Notes : PIC16F690 * '* : * '**************************************************************** _INTRC_OSC_NOCLKOUT ; Using Internal Oscillator _WDT_OFF; Edisable Watch Dog Timer _MCLRE_OFF; disable MCLR _CP_OFF ;Disable Code Protection _CPD_OFF ; Disable Data Code Protection _FCMEN_OFF ; Disable Fail Safe Clock Monitor _IESO_OFF ; Disable Internal/External switchover _BOR_ON ;Enable Brown out detect _PWRTE_ON ; Enable Power up Timer @MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON @MyConfig = _MCLRE_OFF & _BOR_OFF DEFINE OSC 8 ; tells PBP we use a 8 MHZ clock OSCCON = %01110000 ANSEL = 0 ;set all digital TRISA = %110100 ; Set RA5,RA4 and RA2 input, rest output TRISB = %0000 ; PORT B all output TRISC = %00000000 ; PORT C all output CM1CON0 = 0 ' Disable comparator 1 CM2CON0 = 0 ' Disable comparator 2 led1 var portc.4 buton1 var porta.4 led1flag var bit low led1 let led1flag = 0 init: read 10,led1flag pause 2 main: if led1flag = 1 then high led1 else low led1 endif if buton1 = 0 then let led1flag = 1 goto writetoeeprom endif goto main writetoeeprom: write 10, led1flag pause 2 debounce: if buton1 = 0 then goto debounce goto init end
I think on 16F690 must to be defined something to proper work with internal eeprom, but I don't know what.
If I try simple:
Nothing writen in to the eeprom.Code:led var bit let led = 1 write 10, led main: read 10, led SEROUT porta.2,T9600,[led] end
