16F690 read/write
Results 1 to 14 of 14
    Default 16F690 read/write
    Hello,
    I need a little help with read and write to internal EEPROM in PIC16F690.
    I try to write to adress 10, value 1
    like:
    led1 var portc.4
    buton1 var porta.4
    led1flag var bit
    init:
    low led1
    let led1flag = 0
    zac:
    read 10, led1flag
    if buton1 = 0 and led1flag = 0 then goto onled
    if buton1 = 0 and led1flag = 1 then goto offled
    goto zac
    onled:
    high led1
    let led1flag = 1
    write 10, led1flag
    debounce:
    if buton1 = 0 then
    pause 10
    goto debounce
    goto zac
    offled:
    low led1
    let led1flag = 0
    write 10, led1flag
    debb:
    if buton1 = 0 then
    pause 10
    goto debb
    goto zac
    But the program stuck on read and the write instruction.
    On 16F628 I use these commands and it works, on 16F690 I am doing something wrong. Please can someone to explain how use READ and WRITE instruction on this chip. Thanks.
    Default Re: 16F690 read/write
    your pgm is an incomplete undebugable snippet , start here
    Hello Richard,
    here is a complete code with config:
    '*  Notes   : PIC16F690                                         *
     _INTRC_OSC_NOCLKOUT ; Using Internal Oscillator
     _WDT_OFF; Edisable Watch Dog Timer
    _MCLRE_OFF; disable MCLR
     _CP_OFF ;Disable Code Protection
     _CPD_OFF ; Disable Data Code Protection
     _FCMEN_OFF ; Disable Fail Safe Clock Monitor
     _IESO_OFF ; Disable Internal/External switchover
     _BOR_ON ;Enable Brown out detect
     _PWRTE_ON ; Enable Power up Timer
    @MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON
    @MyConfig = _MCLRE_OFF & _BOR_OFF
    DEFINE OSC 8 ; tells PBP we use a 8 MHZ clock
    OSCCON = %01110000
    ANSEL = 0  ;set all digital
    TRISA = %110100    ; Set RA5,RA4 and RA2 input, rest output
    TRISB = %0000     ; PORT B all output
    TRISC = %00000000  ; PORT C all output
    CM1CON0 = 0 ' Disable comparator 1
    CM2CON0 = 0 ' Disable comparator 2
    led1 var portc.4
    buton1 var porta.4
    led1flag var bit
    low led1
    let led1flag = 0
    init:
    read 10,led1flag
    pause 2
    if led1flag = 1 then
    high led1
    low led1
    if buton1 = 0 then
    let led1flag = 1
    goto writetoeeprom
    writetoeeprom:
    write 10, led1flag
    pause 2
    debounce:
    if buton1 = 0 then goto debounce
    goto init
    The WRITE and READ instructions works on 16F628, 16F688 as is in the code, but on 16F690 still not.
    I think on 16F690 must to be defined something to proper work with internal eeprom, but I don't know what.
    If I try simple:
    led var bit
    let led = 1
    write 10, led
    read 10, led
    SEROUT porta.2,T9600,[led]
    Nothing writen in to the eeprom.
    read 10, led
    you realise the chr's 0,1,255 {all the likely eprom values you expect} are unprintable , there is nothing special or different about 16f690 eprom
    SEROUT porta.2,T9600,[#led] or
    SEROUT porta.2,T9600,[dec led]
    is whats required
    and I doubt your config setting is correct
    it could go like this , but why would you
    @MyConfig = MyConfig & _MCLRE_OFF & _BOR_OFF & _FCMEN_OFF & _IESO_OFF
    @ __config MyConfig
    this is the prescribed way
    cfg = _INTRC_OSC_NOCLKOUT
    cfg&= _WDT_ON
    cfg&= _PWRTE_OFF
    cfg&= _MCLRE_ON
    cfg&= _CP_OFF
    cfg&= _CPD_OFF
    cfg&= _BOD_ON
    cfg&= _IESO_ON
    cfg&= _FCMEN_ON
    __CONFIG cfg
    or this
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _CPD_OFF & _BOD_ON & _IESO_ON & _FCMEN_ON
    or this
    Sorry, that is my copy paste error.
    You code for sending the value out is sending unprintable characters to whatever is receiving the serial.
    if your bit is a 0 then that is a null character, if it is a 1 then it is a SOH see here
    http://www.asciitable.com/
    If you want to see the character as a printable digit then add 48 to it
    SEROUT porta.2,T9600,[led+48]
    You could also run your simple program then put the pic back in the programmer, read and view the eeprom data.
    Yes this is true, my serout command is not correct, but if I try simple write in to the eeprom the program stuck and not run next.
    Like:
    led var bit
    let led = 1
    led var portc.4
    write 10, led
    high led
    low led
    led var bit
    let led = 1
    led var portc.4
    write 10, led
    high led
    low led
    once again an uncompilable piece of code,there is nothing special or different about 16f690 eprom . snippets are pointless
    try and post a complete and correct pgm that demonstrates the issue
    Bums12's Avatar
    Bums12 Guest
    I can not delete my message.
  1. SD Card Write/Read
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 28th April 2014, 08:26
  2. PLEASE HELP...read write issues
    By nomad77 in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 14:39
  3. Can't read an sms Using TC35i & 16F690
    Last Post: - 4th October 2009, 22:41
  4. I2C Read and Write
    By DerekMacom in forum mel PIC BASIC
    Last Post: - 21st April 2008, 15:44
  5. cannot read/write to 16F690 data memory after CPD_ON
    By awdsas in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2006, 11:46
