Battery powered applications
Results 1 to 8 of 8
Threaded View
  1. #3
    Feb 2004
    Germany
    Thanks Melanie,
    you are right, chances are that the regulators are slightly off 5.00V, this is something I could compensate as long as the output is relatively stable and there is not too much drift.
    Some of the sensors are integrated types and require a 5.0V supply, so running the circuit at 3.3V or 4.5V is not an option.
    For higher resolution I'm using an external ADC.
    The LP2950 Regulator has an initial tolerance of 0.5%
    and a line regulation of 0.05%
    quiescent current is 75µA "only"
    I'll give it a try.
    Or do you know any "better" Regulator?
    Worst case I would have to solve the problem by throwing battery capacity at it
    regards
    Ralph
  1. How can a battery powered PIC turn itself off?
    By tekart in forum mel PIC BASIC Pro
    Last Post: - 9th August 2012, 10:44
  2. Of battery discharge curves
    By ardhuru in forum General
    Last Post: - 21st January 2009, 16:24
  3. Low battery signal from an RTC
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 17:13
  4. 12F683 battery powered remote - energy consumption question
    By silentwol in forum mel PIC BASIC Pro
    Last Post: - 13th April 2007, 13:23
  5. Battery Powered Need Help!
    By scottl in forum Off Topic
    Last Post: - 29th March 2006, 09:52
