Serout code space
Results 1 to 12 of 12
    Default Re: Serout code space
    IT MAY NOT BE WORTH THE EFFORT ,tried this on a 12f683
    90 words
        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _CP_OFF
    DEFINE OSC 8 'LETS PBP KNOW WE WILL BE RUNNING AT 8MHZ
    'PIN DEFENITIONS
    'GP3
    'GP4 USED FOR TRIGGER INPUT
    'GP5 USED FOR LED
    'SET UP THE  REGISTERS
    OSCCON = %01110001  '8MHZ INTERNAL CLOCK USED
    CMCON0 = %00000111 'CIN PINS ARE I/O, COUT PIN IS I/O
    TRISIO = %00111011 ' GP2  OUTPUT THE REST ARE INPUTS
    ANSEL = 0 'NO ANALOG PORTS - ALL DIGITAL
    WPU = %00010000 'GP4 WEAK PULL UP ENABLED.
        DEFINE DEBUG_REG GPIO
        DEFINE DEBUG_BIT 2
        DEFINE DEBUG_BAUD 9600
        DEFINE DEBUG_MODE 0
    '    LATB.7=1
    'PBP software serial out 8N1
    delay var word ' set baud rate delay
    txbyte var byte ' byte to send
    bcount var byte ' counter
    serpin var gpio.2
    delay = 100 ' set serial delay here   9600
    txbyte = "H"
    GOSUB serialout
    txbyte = "E"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "O"
    GOSUB serialout
    txbyte = $20 ' space
    GOSUB serialout
    serialout:
    Debug  txbyte
    98 words for arts version
    'PIN DEFENITIONS
    'GP3
    'GP5 USED FOR LED
    serpin var gpio.2
    txbyte = "H"
    GOSUB serialout
    txbyte = "E"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "O"
    GOSUB serialout
    GOSUB serialout
    serialout:
    ' start bit
    serpin = 0  ' tx clear
    PAUSEUS delay ' start bit delay
    ' send byte
    FOR bcount = 0 TO 7
    serpin=txbyte.0
    txbyte = txbyte >> 1
    PAUSEUS delay ' data bit delay
    NEXT
    serpin= 1
    PAUSEUS delay ' stop bit delay
    Aug 2003
    Nice
    If it could be matched in space, I’d still prefer to see my own code, just that I’ve never had a reason to do it until now.
    It would be less in asm though, and I still think I could top it.
    It was worth the effort to do with a dsPic where the pin was not mappable to UART, so incidentally tried with PBP as well.
    No BASIC For/Next loop, instead I’d count down to zero.
    No shift command, instead an asm rotate to ensure only 1 instruction,
    My own delay routine, which is conveniently right before a return, so can be called multiple times.
    watchdog timer resets also have to be turned off because PBP won’t put them in it’s own routines, but in YOUR code.
    To my disadvantage, there needs to be some value stored in Delay, which would claim some more space.
    Something like this (untested).. and I can’t remember if PBP labels need the underscore or not.
    count var byte
    pdelay var byte
    serialout:
    @ movlw	,8
    @ movwf	_count	,F
    @ clrf PORTB	,1
    @ call pausedelay
    sendbyte:
    PORTB.1 = txbyte.bit0
    @ rrf txbyte	,F
    @ call pausedelay
    @ decfsz _count
    goto sendbyte
    @ bsf PORTB	,1
    pausedelay:
    @ movlw	,210
    @ movwf	_pdelay	,F
    zpausedelay:
    decfsz _pdelay
    @ goto zpausedelay
    @ return
    asm version 52 words
    'PIN DEFENITIONS
    'GP3
    'GP5 USED FOR LED
    TRISIO = %00111010 ' GP2  OUTPUT THE REST ARE INPUTS
    '    DEFINE DEBUG_REG GPIO
    '    DEFINE DEBUG_BIT 2
    '    DEFINE DEBUG_BAUD 9600
    '    DEFINE DEBUG_MODE 0
    ''    LATB.7=1
    delay var byte bank0 ' set baud rate delay
    txbyte var byte bank0' byte to send
    bcount var byte bank0' counter
    serpin var gpio.0
    ; set serial delay for   9600b
    txbyte = "H"
    GOSUB serialout
    txbyte = "E"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "L"
    GOSUB serialout
    txbyte = "O"
    GOSUB serialout
    GOSUB serialout
     serialout:
    asm
     movlw 8
     movwf _bcount
     bcf     GPIO ,0
     call pausedelay
    sendbyte
     btfss  _txbyte ,0
     goto snd0
     bsf   GPIO ,0
     goto sndd
    snd0
     bcf   GPIO ,0
    sndd
     rrf _txbyte ,F
     call pausedelay
     decfsz _bcount ,F
     goto sendbyte
     bsf GPIO ,0
    pausedelay
     movlw 67
     movwf _delay
    zpausedelay
     decfsz _delay  ,F
     goto zpausedelay
    endasm
    printout from pickit2
    Aug 2003
    Thanks for running it That’s getting worthwhile then. Using Pauseus in the first post would have added code to it.
    I might as well have a shot at the serial input over the next few days then.
    Basically I did this on dspic in C, and it wrote easily into PBP as well.
    The pic at the receive end is supposed to be 16F628A in PBP/asm.
    My mp3 player serial spits out the artist & title info from the ID tags as tracks are skipped (that much is working).
    Then the 16F628A is supposed to receive the serial, and transmit IR to an electronic sign the same way a user would normally use a remote to reprogram the scrolling message
    Aug 2003
    This time going for serial input of a string terminated with either 0x00 or 0x0D (or any value below 0x20 really) into an array.
    So far one byte, and untested, but I do have a PBP program on 16F628A ready to test and use it when done.
    It’s on the receive side where I want serene replaced because I can keep going with my own data until the program memory is full.
    rxbyte var byte
    count var byte
    delay var byte
    shortdelay var byte
    delay = 100 ‘ actual serial timing
    shortdelay = 50 ‘ time/2
    serinbyte:
    IF PORTB.1 = 1 THEN
    ‘ optional countdown to timeout here
    GOTO serinbyte
    pauseus delay
    pauses shortdelay
    FOR count = 0 TO 7
    rxbyte.bit7 = PORTB.1
    rxbyte = rxbyte >> 1
    pauseus delay
    NEXT count
    pauses shortdelay
    rxbyte = rxbyte ^ $FF
    i'd bet this won't stack_up any better than debug either as is
    sram ?
  1. Working code but my layman approach uses too much code space
    Last Post: - 14th December 2012, 21:44
  2. I'm running out of code space example.
    Last Post: - 21st June 2010, 21:33
  3. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  4. Need more code space
    By Sphere in forum General
    Last Post: - 19th September 2005, 21:49
  5. Need more code space
    By ghutchison in forum General
    Last Post: - 12th February 2005, 21:54
