Typically, ICSP is done with a hardware programmer. If or when you get a programmer, it should have some documentation on how to use it for ICSP. If your looking for other options, I know there was a thread some time ago about using a PIC for the ICSP programmer... but I'm not sure that's what you need. Does your project require ICSP? If you're just starting out... you can't beat a good hardware programmer. Maybe some of the guru's have a better idea for you?
