PIC18F2550 ICSP - newbie
Results 1 to 9 of 9
    Mar 2005
    Iowa, USA
    If you know someone who can program a bootloader program to some chips for you, you could program your chip with a serial connection.... As long as your chip is bootloader capable. Pretty cheap alternative.
    Mentor, Ohio
    Smile
    Hello icicle,
    Yes this chip can be programmed using ICSP. This forum has a search tool where you will find countless articles on programmers that are available including schematics on how to build your own. I must really echo the words of the "knowledgeable ones" on this forum (Melanie, Darrell, Dwanye, Mister E, Bruce, and NavMicro (Ralph)) that you should download and read the datasheets on the particular chip you are going to use and spend a few days reading previous posts on this forum to learn all you can before asking questions. It will save you alot of time in the long run. There are also alot of other PIC related sites on the Internet where you can gather great insight into this wonderful product. Rentron.com also has much to offer including tutorials and programming software and tools. Bruce has much to offer including great advise!
    Rhino was right as far as a bootloader being the cheapest programming tool. You only need a hardware serial port on your pic and the bootloader software installed on your pic and a serail cable to your PC.
    Have fun!
    BobK
    icicle's Avatar
    icicle Guest
    Thanks for your replies.
    Yes, I did download and read the datasheet on the 18F2550 and it does say that its supports ICSP, BUT it doesn't say HOW to do it !!
    The Microchip site isn't the easiest website to navigate at the best of times so if you can point me to somewhere that tells me HOW to use ICSP please do.
    Mar 2005
    Iowa, USA
    Typically, ICSP is done with a hardware programmer. If or when you get a programmer, it should have some documentation on how to use it for ICSP. If your looking for other options, I know there was a thread some time ago about using a PIC for the ICSP programmer... but I'm not sure that's what you need. Does your project require ICSP? If you're just starting out... you can't beat a good hardware programmer. Maybe some of the guru's have a better idea for you?
    Feb 2004
    Germany
    Quote Originally Posted by icicle
    A search for "ICSP" on the Microchip site would have taken you to the ICSP Programming Guide
    regards
    Ralph
    icicle's Avatar
    icicle Guest
    Thanks NavMicroSystems.
    I did search the MC site for ICSP and found and read that document - but excuse me for being dumb - it doesn't reference the 18F2550 anywhere. Are you implying that it should be programmed the same as another device ? If so, which one ?
    I think I'm going to buy the ICD2 programmer/debugger - it looks like it supports the 18F2550.
    Feb 2004
    Germany
    icicle,
    see: 18F2xx0 Programming Specs
    BTW
    The ICD2 is an excellent choice!
    regards
    Ralph
    icicle's Avatar
    icicle Guest
    NavMicroSystems : Many thanks - thats exactly what I was looking for.
  1. ICSP and 16F684
    By onaclov2000 in forum Schematics
    Last Post: - 5th March 2009, 17:31
  2. what IS an ICSP connector?
    By mslaney in forum Schematics
    Last Post: - 5th March 2008, 07:05
  3. Replies: 1
    Last Post: - 10th December 2007, 23:57
  4. PIC18F2550 Newbie
    By JeffnDana in forum mel PIC BASIC Pro
    Last Post: - 26th April 2007, 15:13
  5. ICSP Newbie
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 7th May 2005, 09:19
