Strange problem with 'pauseus' command
Results 1 to 6 of 6
    Default Re: Strange problem with 'pauseus' command
    FOR PERIOD_COUNT = 1 TO 187 '20mS PERIOD
    			IF PERIOD_COUNT > PULSE THEN 'MAKE LINE LOW FOR REST OF 20mS PERIOD
    				SERVO = 0 'MAKE SURE SERVO SIGNAL IS NOW LOW
    				SERVO = 1 'SERVO SIGNAL LINE HIGH FOR 1.0 OR 2.0mS
            NEXT PERIOD_COUNT
    this for next loop takes 45us to execute when PERIOD_COUNT is a word var even without the pause, it severly limits resolution
    if you do it this way the resolution is 1 uS or thereabouts
    '*  Name    : hobby_servo.BAS                                   *
    '*  Author  : richard                                           *
    '*  Notice  : Copyright (c) 2016 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/19/2016                                        *
    '*  Notes   : 12f683                                            *
        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _CP_OFF
    DEFINE OSC 8 'LETS PBP KNOW WE WILL BE RUNNING AT 8MHZ
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    'PIN DEFENITIONS
    'GP2 USED TO DRIVE SERVO (SIGNAL LINE)
    'GP3 USED FOR MCLR AND ICSP PROGRAMMING
    'GP4 USED FOR TRIGGER INPUT
    'GP5 USED FOR LED
    'SET UP THE  REGISTERS
    OSCCON = %01110001  '8MHZ INTERNAL CLOCK USED
    CMCON0 = %00000111 'CIN PINS ARE I/O, COUT PIN IS I/O
    OPTION_REG=%01010111      ;set prescaler and assign it to tmr0
    define NO_WDT 1
    TRISIO = %00011011 'GP5 AND GP2 ARE OUTPUTS, THE REST ARE INPUTS
    ANSEL = 0 'NO ANALOG PORTS - ALL DIGITAL
    WPU = %00010000 'GP4 WEAK PULL UP ENABLED. GP3 WEAK PULL UP AUTOMATICALLY ENABLED
        'AS THE PIN IS DEFINED AS MCLR
    @Timer1 = TMR1L ; map timer1 registers to a word variable
    Timer1 VAR WORD EXT
    t1con=0
    wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    ;wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    'Wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    asm
    INT_LIST macro
          INT_Handler   TMR0_INT,   _serv,    PBP,  yes
          INT_Handler   TMR1_INT,   _st,      PBP,  yes
          INT_CREATE
    'PIN ALIASES
    SERVO VAR GPIO.2
    TRIGGER VAR GPIO.4
    LED VAR GPIO.5
    'VARIABLES
    servo_t VAR word 'pulse TIME  in us
    SERVO = 0 'MAKE SURE NO SIGNAL
    LED = 0 'MAKE SURE LED IS OFF
    @ int_enable  TMR0_INT
    @ int_enable  TMR1_INT
    MAIN:
      IF TRIGGER = 1 THEN 'CLOSE THE DAMPER
       servo_t = 2000 '2.0mS PULSE TO SERVO
       LED = 1 'TURN ON LED
      ELSE 'OPEN THE DAMPER
       servo_t = 1000'1.0mS PULSE TO SERVO
       LED = 0 'TURN OFF LED
    serv:
    tmr0=tmr0+100
    Timer1 = -servo_t
    pir1.0=0
    t1con=$11
    SERVO =1
    @ int_return
    st:
    t1con=0
    servo=0
    @ int_return
    Jan 2012
    Grid EN19MV
    '* : All Rights Reserved *
    '* Version : 1.0 *
    '* Notes : 12f683 *
    I thank you Sir. MUCH better resolution, like you said. While I have used DT's Instant Interrupts a little,
    I have not used them a lot. I'm starting to get a handle on how you did that. In fact, I may port this over
    to an 18F2550 so I can use debug to watch everything to help my understanding.
    Thanks again,
    Andy
    -Stephen Hawking
    it should be pretty straight forward to get it to work on a pic18.
    trying to debug/watch isr's in action is an art form in itself especially when they need to run at full speed to function realistically or even at all.
    try this version if you want to regulate the speed the servo
    ps the osctune setting is for my particular chip others may/will need a different value ,see data sheet
    I chose a value that gives me an accurate 2mS pulse for a servo_t value of 2000 / trial and error
    '*  Notes   : 12f683                                            *
    '*          : now with speed control and osc tuned for accuracy *
        __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
    'PIN DEFENITIONS
    'GP3/mclr  USED FOR TRIGGER INPUT
    'GP4 vacant
    'GP5 USED FOR LED
    define NO_WDT 1
    Timer1 VAR WORD EXT
    t1con=0
    OSCTUNE=3  ;trim best way
    closed   con 2000
    open     con 500
    asm
    INT_LIST macro
          INT_CREATE
    'PIN ALIASES
    SERVO VAR GPIO.2
    TRIGGER VAR GPIO.3
    LED VAR GPIO.5
    'VARIABLES
    tick var byte
    mvflg var bit
    servo_t=open
    LED = !TRIGGER
    MAIN:
          while  servo_t < closed
           servo_t = servo_t + 20
           mvflg=0
           while  !mvflg  :wend
          wend
          servo_t =  closed
       LED = 0 'TURN ON LED
          while  servo_t > open
           servo_t = servo_t - 20
           mvflg=0
           while  !mvflg  :wend
          wend
          servo_t =  open
    serv:
    tmr0=tmr0+97
    Timer1 = ~servo_t;+50    alternative trim method
    pir1.0=0
    t1con=$11
    SERVO =1
    tick=tick+1
    if tick.0 then mvflg=1
    @ int_return
    st:
    t1con=0
    servo=0
    @ int_return
  1. Strange problem with button command and loop
    Last Post: - 14th April 2013, 07:10
  2. A strange problem
    By mombasa in forum mel PIC BASIC Pro
    Last Post: - 25th January 2012, 21:08
  3. Very strange problem...
    By alanmcf in forum mel PIC BASIC Pro
    Last Post: - 7th May 2011, 06:28
  4. strange problem 12f675
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th July 2007, 13:47
  5. PAUSEUS command
    By AndrewC in forum General
    Last Post: - 10th February 2006, 03:00
