Math for A/D conversion
Results 1 to 7 of 7
    Pickplayer's Avatar
    Pickplayer Guest
    Default Re: Math for A/D conversion
    Henrik: Yes it is still a question The values in the variable are after divide// for remainder with 0 as leading bit remainder = 0498 any time I have a remainder in a calculation of leading bit 0 debug will not read it. for instance if the remainder is 0498 debug reads 498, if I debug dec 4 then it will read all four digits. If I debug dec2 then it reads 98. I hope I made myself clear enough as to understand my delema.
    And the answer is the same as before. Divide by 100 then use DEC2 to display the result.
    If the variable contains 498 and you want that to display as 04 after a decimal point divide by 100 (result = 4) use DEC2 to display with a leading 0. And, again as before, if you rather round than truncate add 50, then divide by 100, then use DEC2. HSEROUT[DEC2 (498+50)/100] will display 05.
  1. Help with the conversion math
    Last Post: - 14th December 2014, 19:58
  2. AD conversion
    By CipiCips in forum mel PIC BASIC
    Last Post: - 19th May 2011, 02:09
  3. PBPL Math...new math takes more cycles...Always?
    Last Post: - 10th February 2008, 11:22
  4. conversion
    By pramodsinha in forum Forum Requests
    Last Post: - 19th January 2006, 16:58
  5. ºC -> ºF Conversion
    By CocaColaKid in forum General
    Last Post: - 15th March 2005, 10:42
