Interrupts Revisited
Results 1 to 13 of 13
    If you jump to or call a sub-routine outside the ISR DISABLE / RESUME, ENABLE block, PBP will shoot you straight back to the beginning of your ISR once the 1st BASIC instruction outside this protected area completes execution.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2005
    antipolo city, philippines
    Default similar problem
    rob,
    i think he had the same problem in using the ON INTERRUPT method. maybe you would want to consider the ASM interrupts. Its a lot more easier than microcode interrupt. just for an idea.
    DEFINE INTHAND IntHandler
    ...(define your variables)
    Initialize:
    TRISB = $FF
    INTCON = %11001000 ;(enable portb change interrupt)
    OPTION_REG = $7F ;(pulls ups enable)
    ... (then your main routines)
    @_IntHandler ;Interrupt Service Routine
    INTCON.3 = 0 ; disable portb change interrupt while in this routine
    ;(reset all necessary variables and call your extra routines)
    INTCON.3 = 1 ; reenable portb change interrupt
    @retfie
    Well I hope this one will give you some ideas. ON INTERRUPT is hard to implement with so much latency compared asm interrupt. As another advatage, you saved some words since ON INTERRUPTS have so many overheads inserted per each of your line since it polls interrupt flags. ok?
    regards,
    Paul
    Aug 2005
    Default in addition to this
    in addition to this, save all your status, W and other registers if necessary when the program is interrupted. just reload it later. in your case i don't think you will to save your last state when interrupted, or just correct me if im wrong.
    regards,
    yettie
    Mar 2004
    The routine I call outside of the ISR has DISABLE & ENABLE either side of it.
    It was my understanding that I can call this other routine and that it will complete the routine then jump back to the ISR.
    This part appears to work fine. My problem is/was that even when an interrupt hasn't occured my code inside the ISR seems to the execute?
    (it seems to execute the "ELSE" statments)
    Can someone confirm I have the correct flags bits set and clear for the "on change" interrupt.
    Lastly having local VARS, I have compiled like this before and never had a problem. Does the compiler just pick the VAR out at compilation time regardless of where they are?
    Again with the ON INTERRUPT call does this need to be anywhere specific? it seems to my no difference where I put it.
    Rob
    Try adding this to the end of your ISR before returning;
    Dummy = PORTB ' read port into Dummy var to end missmatch condition
    INTCON.0 = 0 ' clear RB interrupt flag bit
    Clearing INTCON.1 clears RB0/INT External Interrupt Flag bit. Not RB interrupt on change.
    -Bruce
    tech at rentron.com
    Mar 2004
    Bruce
    Let me take one step back.
    Here is the code I used originally to test my PCB
    You said I was clearing the RB0 flag which I agree with but unless I clear this the program doesn't work!!
    If I use the INTCON.0 = 0 the code doesn't work but using INTCON.1=0 makes the program work.
    I'm very confused and going round in circles as what I would expect to work doesn't. Do I need to enable the Global interrupt GIE INTCON.7=1 before exiting the ISR?
    I've reread the 16f877 data sheet and what I'm doing shouldn't work, but it does.
    Rob
    DEFINE LOADER_USED 1 'Boot Loader
    'Define inputs held low by external resistors
    sw1 VAR PORTB.6
    sw2 VAR PORTB.4
    SW3 VAR PORTB.0
    ' Define the pins that are connected to LEDs
    led1 VAR PORTC.0
    led2 VAR PORTC.1
    INTCON.3 = 1 ' Enable the RB port change interrupt
    OPTION_REG = $7f ' Enable PORTB pull-ups
    TRISC = %00000011 ' Set PORTB.0-2 (LEDs) to output, 3-7 to input
    on interrupt goto ISR
    main: ' main program begins here
    ' Check any button pressed to toggle on LED
    NAP 7 ' Go to sleep. When the watchdog is
    ' disabled, NAP won't wake up until
    ' an interrupt occurs.
    GoTo main ' Do it again upon waking
    DISABLE
    :ISR
    IF sw1 = 1 Then
    high LED1
    low led1
    IF sw2 = 1 Then
    HIGH led2
    low led2
    IF sw3 = 1 Then
    HIGH led1
    HIGH led2
    low led1
    low led2
    '***HERE*************
    'INTCON.0 = 0 ' Clear the RB port change flag bit( this doesn't)
    INTCON.1 = 0 ' Clear interrupt flag (this works)
    RESUME
    ENABLE
    INTCON.3 = 1 turns ON RB Port Change Interrupt Enable bit. This means any change on RB7, 6, 5 or 4 will generate the interrupt.
    There are a few things to watch out for when using this.
    1. Set the upper 4-bits up as inputs. TRISB = %11110000 (assumes only top 4 are used as inputs) change as required. And make sure these inputs are not floating by using internal or external pull-ups - or external pull-downs depending on your switch open/close logic.
    2. Do a "read" of the port before turning ON RB int change. Dummy = PORTB.
    Just take a snap-shot of portb inputs before turning the option on.
    3. INTCON.3 = 1 Now any change from the last value read on RB7,6,5 or 4 will cause the interrupt flag bit INTCON.0 to be set (RBIF: RB Port Change Interrupt Flag bit)
    Now, before exiting your ISR, you need to read portb again, then clear the flag bit associated with RB int change.
    Dummy = portb ' end missmatch
    INTCON.0 = 0 ' clear interrupt flag bit before re-enabling interrupts
    RESUME
    ENABLE
    Some other things to consider.
    You're testing upper portb pins in your ISR. This actually reads the port, and will end the missmatch, BUT, your program is going to run much faster than than anyone can operate a push-button switch, and you will have switch bounce.
    What can happen is you enable RB int on change, someone releases the switch, and you have the interrupt "missmatch" condition all over again.
    You might want to include some code that recognizes the keypress, and then waits for the user to release the key before reading the port, and re-enabling the interrupt on change. You can turn ON the LED immediately, but wait for the key to be released before reading the port & re-enabling int on change.
    Also, you're turning ON internal pull-ups, and you're testing input pins for logic 1 with IF SW1 = 1 THEN do something.
    What logic level does a switch press apply to your switch inputs?
    Definitely not. Exiting the interrupt with RESUME, ENABLE handles everything for you. Using ON INTERRUPT you never need to mess with GIE unless you want to totally disable interrupts. In that case write INTCON = $80 like shown in your manual.
    -Bruce
    tech at rentron.com
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 06:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
