Conflict receiving RS485 stream
Results 1 to 2 of 2
    Feb 2005
    GREECE
    Default Conflict receiving RS485 stream
    Hello Boys&Girls,
    I hope you are well.It is time for holidays not for work but...money!!!
    Let's talk about PicBasic Pro.
    I have a problem with my code.I have a 16F628A which receives a rs485 stream.The device that transmit the stream is the master and it can <<talk>> with 128 slave devices.My pic is a slave device so it has a header(an address).
    When I don't receive the stream my code loop MAIN it is working propertly.
    When I receive my pic reads ok the stream but I can not go to MENU label while the conditions of porta.3 &porta.4 is 1.
    Here is my code:
    MAIN: IF PORTB.6 = 1 THEN STATIC
    WHILE PORTA.3 = 1 AND PORTA.4 = 1 <--it does not work when I it receives
    GOTO MENU
    wend
    DYNAMIC: IF RCIF = 1 THEN
    HSERIN 300,MAIN,[WAIT(X),STR SERDATA\17] ;X = header - address
    GOSUB OUT
    gosub SERTALLY
    GOTO MAIN
    Nikos Geronikolos
    Feb 2004
    Germany
    Quote Originally Posted by ngeronikolos
    -----------------------------------------------------------------MAIN:    IF PORTB.6 = 1 THEN STATIC
      GOTO MENU
      wend
       GOSUB OUT
       gosub SERTALLY
       GOTO MAIN
    what do MENU, OUT and SERTALLY do?
    and...
    you are using a While...Wend loop that is jumped out of as soon as the condition in the While statement is met.
    That doesn't make much sense, better would be something like:
    IF PORTA.3 = 1 AND PORTA.4 = 1 THEN  GOTO MENU
    regards
    Ralph
  1. RS485 splitter
    Last Post: - 30th August 2009, 07:04
  2. USB to RS485
    By The Master in forum USB
    Last Post: - 3rd January 2009, 04:49
  3. Using 16f676 with comms
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 21:01
  4. USB Receiving a Word
    By sean-h in forum USB
    Last Post: - 9th October 2005, 17:56
  5. How can I read an RS485 stream?
    Last Post: - 20th July 2005, 15:26
