Blinking LCD with using loop
Results 1 to 6 of 6
    Jul 2005
    Default Blinking LCD with using loop
    How can I rewrite the following code to display the text constantly instead of looping. It blinks because of the pause but if I take the pause off then the timing gets out of wack and the LCD displays funny characters. Also when I switch on the circuit, the LCD displays "pressed" for a few cycles before going back to "press button" mode. Basically I would like the "press button" constantly without blinking until the button is pressed and then to display "button pressed" without blinking.
    Thanks in advance
    Juan
    Include "modedefs.bas" ' Include serial modes
    DEFINE BUTTON_PAUSE 20 ' button debounce delay is 50ms
    TRISA = %00000000 ' All the PORTA pins to outputs.
    TRISB = %11111111 ' All the PORTB pins to inputs.
    I con 254 '254h = 1111 1110 (Sets LCD to command mode)
    ClrScr con 1 '01h = 0000 00001 (Clears Screen & goes to position 1)
    Line2 con $C0 'COh = 1100 0000B (sets address to positionn 40 on LCD)
    DispCur con 12 '12h = 0000 1100 (activates display & cursor mode)
    'Commands obtained from LCD article in epemag.com
    pause 400 ' Allow LCD to boot up
    LOOP: IF PORTB.2 = 0 THEN
    serout PORTA.1,T9600,[I,clrscr]
    Serout PORTA.1,T9600,["Press Button"]
    if PORTB.2 = 1 THEN
    SEROUT PORTA.1,T9600,["Button Pressed!"] ' Indicate Button Pressed
    goto loop
    Wink
    Hi, juan
    you just send your message to the LCD ... IF there is a change for button position ...
    Since it's your first post...
    Start:
        while PORTB.2=0
              ' Wait untill push-button is pressed
        wend
        pause 1000 ' delay 1 sec
        goto start
    BUT more than often PORTA contain some analog stuff... SEROUT may work properly or not. Look for CMCON or ADCON1 to see how to disable them
    Your Define BUTTON will not do anything if you don't use BUTTON command.
    Wink
    Just 3 lines to add between PAUSE 1000 and goto start ( at the end ...) in case you keep the finger on the pressed button ...
    while PORTB.2=1
    ' Wait until push-button is released
    wend
    Dec 2003
    Wichita KS
    Only do a clr screen at the beginning of your program. before your loop.
    Send a command to position curser at the beginning of the LCD line. in your loop
    granted it will be overwriting what is already there, but who cares?
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Jul 2005
    Thumbs up
    Lovely, thanks fellas, much appreciated. I got picBasic a few weeks ago and I havent stopped playing what I call "lego for adults" since. Hope I can be as good as you guys one day.
    Much appreciated!
    Juan
  1. Controlsystem for compact sporting (clay shooting)
    By Fredrick in forum mel PIC BASIC Pro
    Last Post: - 30th July 2009, 16:48
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  3. Play with LCD on PICDEM
  5. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 17:42
