16F676 Help?
Results 1 to 6 of 6
Thread: 16F676 Help?
    vicce's Avatar
    vicce Guest
    Unhappy 16F676 Help?
    dear friends,
    I am using a 16f676 and I need help to configure the begin of the program.
    I will use porta.0 and porta.1 as analogical and the remaining as digital.
    I will use internal oscillator without master clear.
    friends help-me in these initial configurations
    thank you very much,
    vicente de paula neto(Sao Paulo-Brazil)
    excuse my terrible English.
    Smile
    Hi, Vicce
    Everything you need is here : http://www.farnell.com/datasheets/41570.pdf
    or from Microchip main site : http://ww1.microchip.com/downloads/e...Doc/40039c.pdf
    I don't want to soud like a broken record but...
    To get some example, begin a search with
    1. PORTA AND ADCON => this will lead you to some configuration
    2. Configuration AND fuse => this will lead you to the FAQ on a excellent thread who'll teach you how to find/use PIC fuses (internal osc and such)
    Later if you still need some tips, just send what you have tried.
    vicce's Avatar
    vicce Guest
    Question 16f676
    friends,
    this is writing for a 16f873 and it is exactly this that I need for a 16f676
    Define ADC_BITS 10 ;Set number of bits in result
    Define ADC_CLOCK 3 ;Set clock source (3=rc)
    Define ADC_SAMPLEUS 50 ;Set sampling time in uS
    TRISA = %11111111
    ADCON1 = 4 ;Set PORTA analog and right justify result
    OPTION_REG = $7f ; Enable PORTB pullups
    in the place (pull-up) portb to configure for porta
    in advance thankful.
    Quote Originally Posted by vicce
    There's no Pull-up on PORTA. Must use external one wich is always the best pratice... well IMHO.
    AND PIC16F676 have internal comparator on PORTA, as i thought, so you must add
    CMCON=7
    to the top of your code
    CMCON=7, click,CMCON=7, click,CMC, click,CMCON, click,CMCON=7, click...
    AND, the last one, ADCON1, is not the one you need to set A/D channel. You need to set ANSEL
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=406&stc=1">
    Mar 2005
    Iowa, USA
    Exclamation
    Quote Originally Posted by mister_e
    Although I agree an external pull-up is better....
    TFM states...."Each of the PORTA pins, except RA3, has an individually configurable weak internal pull-up."
  1. Unable to set fuses on 16F676
    Last Post: - 19th January 2012, 18:21
  2. PortA.2 on a 16F676
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 13:59
  3. SEROUT workaround for 16F676
    By rkeene0517 in forum Code Examples
    Last Post: - 12th February 2006, 03:39
  4. Using 16f676 with comms
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 20:01
  5. "Write" with 16F676
    By Jrocci in forum mel PIC BASIC Pro
    Last Post: - 16th December 2003, 17:38
