PBP RAM allocation - how to find available or total used RAM?
Results 1 to 19 of 19
    Aug 2003
    Default Re: PBP RAM allocation - how to find available or total used RAM?
    PBP should put its own system variables first to ensure they are in bank 0.
    From there, one way might be to declare a bunch of the biggest arrays
    that are supported, alias the elements of the arrays once you've determined
    where PBP put them (at least they will be continuous chunks).
    From there, if you don't add any more macro type commands that require
    more RAM for PBP, the locations of your arrays shouldn't change.
    Nov 2016
    Thanks for the comment but you're missing the point of my problem.
    It's not a problem of "moving variables" per se. I know that PBP allocates its (system) variables first etc. The problem is how to determine the first free or last last used location
    in RAM.
    I need that because I would like to configure some buffers at runtime (cannot use static allocation/reservation!) and for that to function "reliably" I need to know the last used/first free RAM location.
    (basically I need 2-3 buffers/arrays of variable sizes which all together could use up to "max free ram". I cannot configure the relative sizes during compile time)
    The easiest way could be as I tried by manually declare a "variable" of specific type at the end... but that is not working as described in PBP manual under "RAM Allocation" - so it's not reliable.
    The only other way I can think of right now, is to parse the .LST file, find there all the declarations of XXXX equ RAM_START + nnn (and check the declaration in the comment about the size) to deduce the "first free" ram location. But this is really an "ugly" way...
    MCulibrk
    Sep 2009
    I needed same thing, more than one time...
    And I finally decided to create small app to monitor .lst file.
    If you trust me, you can try it.
    Right click, Save link as >>Removed, Bug... <<
    Remove .txt extension, unpack RAR archive
    Password: pedja089
    It doesn't handle arrays with constants for size, eg
    X con 4
    MyArray VAR BYTE[X]
    And it doesn't handle include files.
    But if you have any variable declared after any unsupported lines, it will handle it. Or it should... I didn't want to recreate half of assembler to get that 2 things to works...
    Basically it looks for last "RAM_START +", extract number, and try to get line before that, to check type of variable, and if it is array. So it can give correct size.
    DISCLAIMER: Use it at own risk!
    EDIT:
    It uses .net framework 3.5. So you need to have it installed or higher.
    Sep 2009
    Fixed: PicBasicRamMonitor.rar.txt
    Aug 2003
    I understand now. What output does the program have if it was able to simply tell you?
    I can see it happening in about 15 lines. About 5 lines of inline assembler would go a long way here,
    because the file select register does not care what you or PBP is doing with RAM,
    and can simply cycle the entire RAM map (switching banks inbetween) and list all of the values..
    From there, if you populated all of YOUR RAM with an arbitrary value, the unused segments could
    easily be identified (or the largest free space found).
    An then finally, reset YOUR RAM back to zero as if the program had just started.
    Off to tea right now, but if that’s what you mean, will be back later tonight.
    Smile Re: PBP RAM allocation - how to find available or total used RAM?
    the CLEAR cmd already does that
       CHK?RP  FSR0L
       movlw   low (RAM_END)
       movwf   FSR0L
       movlw   high (RAM_END)
       movwf   (FSR0L) + 1
    loop    clrf    POSTDEC0
       movf    FSR0L, W
       iorwf   FSR0H, W
       bnz     loop
       clrf    INDF0
    you are still left with the dilemma on how to fill all the "ram" your pbp code has claimed to a value other than 0
    so you can detect the end of pbp's allocation, might as well examine the .lst
    have found pedja's pgm is not correct when include files are used {as warned}
    you could always do it like most c compilers
    they just keep allocating ram from the heap until the stack underflows ,then let the pgm crash and burn
    Aug 2003
    I meant filling all of the RAM you declared yourself within PBP in a for loop (within PBP) first.
    If all of the RAM is delayed as arrays, this is easily done with a for next loop.
    Then even if you didn’t want arrays, you could still alias the individual elements and forget they are array elements.
    I’m assuming that PBP will put all of your variables after it’s own system variables, even if they are scattered,
    which I believe it always will.
    byte i
    byte PBPvar
    FOR i = $20 TO $80
    @ movf _i , W
    @ movwf FSR
    @ movf INDF , W
    @ movwf _PBPvar
    LCDOUT “PBPvar"
    NEXT i
    If your pic has greater than 8 bit registers you can set the high byte once, outside of the loop.
    This is not tested of course, but the basic idea.. list locations 0x20 - 0x80 (and I don’t actually know where your RAM is in the 18F chip).
    bank switch in PBP and repeat.
  1. Need Help ON the SPI F-RAM....
    By hankshone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2010, 19:29
  2. RAM not reseting
    By InitialDriveGTR in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2010, 20:24
  3. RAM test
    By Sach_1979 in forum General
    Last Post: - 24th September 2009, 23:12
  4. Ram Gets Cleared
    By ljubex in forum General
    Last Post: - 7th November 2005, 00:38
  5. And last but not least: static ram?
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 1st November 2004, 05:37
