Random PBP
Results 1 to 15 of 15
Thread: Random PBP
    strujnimen's Avatar
    strujnimen Guest
    Default Random PBP
    I need code to generate random number from 1 to 7 in PICBASIC PRO. How to? Thanks.
    Might not be the best way, but here is one way (untested):
    random_word var word
    randomdig var byte
    generate_random:
       Random random_word               'generate random number and put into random_word var
       randomdig = random_word DIG 1 'read only first digit
       if randomdig = 8 then goto generate_random 'if its 8 then do over
       if randomdig = 0 then goto generate_random ' if its 0 then do over
    Oh yeah, and filter out 9 as well.
    Omaha, Nebraska USA
    To filter, you can also use:
    if randomdig > 7 or randomdig < 1 . . .
    Russ
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    PBP's RANDOM command is FAR from RANDOM.
    Makes good pink noise though ...
    But anywho ...
        RANDOM   RandVar
        Result = RandVar ** 7 + 1
    Omaha, Nebraska USA
    Just how far from "random" is it?
    Russ
    Quote Originally Posted by RussMartin View Post
    Pretty FAR!
    It's a REPEATING sequence of 65535 numbers.
    If you start with the same "Seed" each time ...
    You will get the exact same numbers every time you run your program.
    If you start with a different seed, all that does it put you somewhere in the middle of that same repeating sequence.
    There's really nothing "RANDOM" about it.
    It's called pseudo-random, but even that's a stretch.
    Feb 2008
    Michigan, USA
    OK.....
    What is the best way to approach the need for the appearance of "random"?
    I have seen that there is a pattern and haven't figured out a way to circumvent it other than to make the sequence long to make it harder to see the pattern (LEDs)
    Mark
    Default Re: Random PBP
    But anywho ...
        RANDOM   RandVar
    This is an older post I searched because I need to generate a random number and saw you can do it with a word variable. Like this fella, I need a smaller number.
    I'm having a hard time grasping what is going on with Result = ** 7 + 1
    Huh ?
    Saw --
    ** Returns the high 16 bits of a 16-bit multiply result
    But even that isn't making sense to me.
    Has there been any updates to random where you can apply it to more than a word? -thanks
    That line of code will scale the WORD sized Randvar variable (0 to 65535) to a value ranging from 1 to 7.
    Bascially it's the same as doing Result = Randvar * 7 / 65536 + 1
    Use biased zener connected to ADC and sample the input
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 09:47
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. 6 random numbers limiting to 49 ?????
    Last Post: - 16th June 2005, 00:27
