quick question
Results 1 to 5 of 5
Thread: quick question
    Default quick question
    I have 4 identical circuits. If I put at the top of each program:
    X var word
    pause x
    and power up all 4 at the same time, will X be a random number on each of them? The idea here is to make all 4 flash an LED but I don't want them to do it at the same time. Will this work or should I generate a random number for X in a more conventional way? Thanks
    Default Re: quick question
    Peter, I would personally start one of the 16 bit timers (if it has 1) and then read it and use it as the SEED for the random command whoes output would be scalled and used as the PAUSE variable.
    EN82fn
    x will most likely be 0 or 65535 when you apply power. Getting a truly random number is actually quite hard. Perhaps a long wire or PCB trace acting as an antenna feeding an analog input and sample it on power on.
    Aug 2003
    One way to get a “sort of random number” is to start a timer, and then let the watchdog timer do a reset which will not ruin the timer values.
    Then you can read them and you get different values each time in some limited range that you could multiply or divide.
    The next time the program starts after the reset, the timer values will be non zero before you started the timer. Then service the watchdog timer from then on.
    I left an example here at some stage that allowed a pic to determine from a list of specific values, what speed crystal is running the pic.
    Another way might be to let the POT command do what it does, and time the discharge of a capacitor through a resistor.
    You should be able to fiddle with resistor and capacitor values to make the POT command return inconsistent readings.
    Can you add a pot?
    I'd connect it to an analog input, read the value, establish a pause or loop on that value then start main loop.
  1. A quick question.....
    Last Post: - 17th December 2010, 15:25
  2. Quick DS18B20 question
    By gti_uk in forum General
    Last Post: - 21st June 2009, 18:24
  3. Interrupt Quick Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 06:51
  4. quick question
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2004, 02:45
