Automatic turn off
Results 1 to 23 of 23
    Quote Originally Posted by AMay
    The attachment to my original message got lost it seems, so here it is.
    In the past I tried with mosfets but the results were disapponting.
    Then I used an PNP transistor much like Melanies post. I think that circuit as was presented by Melanie is the best up to this moment.
    Question on/off
    Hi
    Why not use a simple regulator with Enable pin ??? ( i.e LM 2941 ...)
    Quote Originally Posted by Acetronics
    Hi
    Because at least 300uA is needed when in OFF state!
    Still the previous circuit with an PNP like BC557 or BC856/7/8 is the #1.
    Wink and, moreover saying "papa and mamma" ...
    Ioannis,
    this was an Example .... have a look to other brands too ( Micrel 29xxx ( 1µA ) ... etc, etc ).
    Hi Alain. No offense :-)
    300 uA or even 1uA might on some cases be too much. With the BC857 that I mentioned I could not measure the leakage current with the Fluke 179 multimeter (as voltage across a R).
    P.S. On the real circuit, note that the PCB has to be cleared from solder because the leak may be more than the electronics in some cases!
  1. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 20:19
  2. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 22:27
  3. Help with PIC project
    By davekav in forum General
    Last Post: - 17th April 2008, 23:15
  4. Interface for 16f818
    By davekav in forum Serial
    Last Post: - 17th April 2008, 11:33
  5. LCD will not start
