I ended up using a SPST switch on mine....
They sell these dirt cheap all over the place... with 20 MILLs and less to operate...
I put the switch to make contact across the Terminals, and as soon as the contact is made, the PIC stuck 20 mills across the load to keep it on. The you can do whatever you want....and the PIC will turn it off 100 percent. run 3 1.5 volt batterys and presto...
Attached is a image... Please do admire my artistic abilities...<chuckle>
Dwayne
