I have finished my timer project, and I think it came out pretty well. Pictures attached. As usual, a project starts out very simple, but when you find it necessary to accommodate humans, things get more complicated.
First, I determined that the user needed to see some continuing action for reassurance that the unit was working, so I added a flashing led. Also, some means of resetting, or starting over, so you don't have to wait 'till the time runs out to begin again. This was done by the program.
I found that the sonalert buzzer needed to be glued to the case, lined up with matching hole. I first tried putting it on the circuit board, but the sound was muffled too much. I used Goop glue, which seems to stick to everything.
I liked the result so much, I made two. One to pass along with a 9 volt battery, and one to keep. The keeper has a 3.6 volt lithium battery with wire leads soldered to the board. I figure that the lithium battery will last over 1000 hours. The PIC uses about 1.7 ma, and the buzzer and led are not on very much of the time.
The off current is not measurable by the equipment available to me. My Fluke meter reads .1- .2 ua, either in or out of the circuit when it is "off."
I appreciate the help and advice I have received. Thanks to all those who offered suggestions.
AMay
